Sky InsuranceBadger5
Results 1 to 8 of 8
    2008 Audi S3
    Oct 2007
    South Africa
    197
    Where to run power cable in 8P S3?
    Hi,
    As per topic, any tips on where I can run the power cable for an amp on a RHD 8P S3? I've tried to look but wasn't very succesful. Just wanted to get some ideas on where it through the firewall. I saw one grommet on the passenger side on the firewall but half the aircon is on the other side. It's a 4 gauge cable if size matters.
    2008 Audi S3
    Oct 2007
    South Africa
    197
    *bump* anyone?
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    I would think that the passenger side would be the place. The grommet would probably be it. AndyMac is probably the man to speak to as he is the man, who helped me with my 8L S3.
    Most probably you'll need to take the glovebox out with some trim to get to the grommet from the passenger side.
    Jun 2003
    World of my own
    9,813
    Never worked on an 8P so wouldn't know for definate. If you have DSG then you can use the blanking grommet where the clutch cable would have been. Alternatively the easiest route is usually through the ECU cover which normally drops straight into the drivers side footwell. There's a lot of cables that run through there.
    On the 8L theres a handy grommet in front of the pollen filter (passenger side under the wiper scuttle) but not sure if this is the same on the 8P.
    Alex Turner
    2008 Audi S3
    Oct 2007
    South Africa
    197
    Yeah had a look and there is a grommet in the section that does the rain catch (where the wipers go on). I'll try dig up in Elsawin how to remove it, I suppose it's park the wipers in maintenance mode, unbolt them and pull the plastic cover off.
    RGC
    RGC's Avatar
    I void warranties"!
    Aug 2008
    NORTH EAST UK
    148
    could the power from the stock factory fitted amp not be tapped from the back to run a after market amp ?
    Jun 2003
    World of my own
    9,813
    What the puny 5 amp cable? I don't think so, unless you want the car to catch fire. You need to run a proper 40 amp, 8 gauge or bigger cable straight to the battery to run any proper amp.
    Alex Turner
    RGC
    RGC's Avatar
    I void warranties"!
    Aug 2008
    NORTH EAST UK
    148
    Pictures of clutch pedal blanking grommet
    installed my amp today and took some pictures of that blanking grommet where the clutch pedal would have lived if my car wasn't a DSG
