Chris NottJMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
  1. #41
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I've done about 10 of these, they are pretty straight forward.
    1. Run the cluster speed pulse to the harness.
    2. Recode to A6 and reset.
    I learnt the hardway like yourself by spending nearly 6 hours on the first one I did, until I could get the pointer to move in Nav mode I couldn't install the unit. It was down to coding and not doing a reset of the unit.
  3. #42
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Quote Originally Posted by s8craig View Post
    Yep, 0502111 no BOSE and make sure adaptation channel 8 is set 0 ~ 5
    or
    0509111 if your car has BOSE and make sure adaptation channel 8 is set to 255
    Think that adaptation channel bit i got confused.
    anyway, double checked wires, wil volt meter, its all connected.
    but... i droped my bloody laptop the one with vagcom so now the hard drive is screwed
    my car battery is now dead,
    lol
    stresssss
    just waiting for battery to charge then ill take it for a spin, and hopefully it should work (i doubt it very much tho)
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
  4. #43
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Took it for a spin, but sat still doesnt work, 100% speed signal
    Still need Remap
    2007 Audi S3 8L
  5. #44
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Ah well if you around this weekend and fancy a trip, you know where i am
  6. #45
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Thanks Craig, am still going to try and master it and will let you know what happens
    Still need Remap
    2007 Audi S3 8L
  7. #46
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Craig,
    just checking
    Behind the cluster, the blue block
    is it behind the rev counter, left hand side ?
    Still need Remap
    2007 Audi S3 8L
  8. #47
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I don't know whcih it is, but there are only 3 connectors, green, grey & blue
  9. #48
    hharry100's Avatar
    Feb 2007
    west london
    52
    If i can remember correctly its the blue connector behind dash pin #3 and its a blue and white wire connect this to pin B3 (v-signal pin) on your RNS-E, also make sure its coded for an a6 otherwise it does not pick up the speed signal.
    Dolphin grey 03
    Gmbh handling pack
    Defcon 2
    H&R roll bars
    RNS-E (dvd, Digital tv tunner)
    Custom Code
    Porsche Brake set-up
    Dieselgeek stigma short shift
    *NEW* 8P s3 FBMFSW
  10. #49
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    did it get you home rik ?
    LOTS DONE, LOTS SPENT !!!!
  11. #50
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Finally its all sorted
    Big Thanks to Craig for all the above help
    and 1Wheelonly for the vag com coding
    Thanks alot both for all the info and help, and thanks for working in the cold 1wheel and adding the extra things via vagcom.
    Very happy i am now, Next mission- bring on the bluetooth lol
    Still need Remap
    2007 Audi S3 8L
