Hi guys
I have a very odd problem that I just cant work out to do with my radio
Original thread was started here . http://www.audi-sport.net/vb/showthread.php?t=57899
My radio keeps putting its self into Safe Mode and it driving me nuts.
Ive tried a numbers of things including
1, Disconnecting the top block, no ignition, entering the code and the radio will work (Front speaks only)
As soon as I turn on the ignition the radio goes back to safe mode
Note - No DIS and No Sub and rear speakers as they are not connected
2, Disconnecting the top block, With ignition on, entering the code and the radio will work (Front speaks only)
Radio will then stay on even with the ignition off until I press the button to turn it off
3, All three blocks plugged in to the radio, ignition off, enter the code and the radio, all speakers and the sub work.
As soon as I turn the ignition on the radio will return to Safe
This is where is gets odd !
4, All three blocks plugged in to the radio, ignition off, enter the code and the radio, all speakers and the sub works
Then if I turn the lights on or any other electrical part of the car the radio jumps in to Safe
I can never get to DIS to display the radio but the DIS will display when Im low on fuel, trip, etc
Ive checked every fuse and they are fine
I've checked near the sub to see if its wet and its not. Plus the subs and rears will work fine when I dont have the ignition on
Baffled !
Baffled !
