JMB RetrofitsEM Tuning
Results 1 to 9 of 9
    Apr 2008
    Luton
    61
    hard wiring inverter into the boot - S3 8L
    I've got a power inverter for my s3 so I can run the ps2 in the car, I've got it all plumbed in but I have to run the power cable to the front so I can plug the inverter in.
    So what I wanna do is hard wire the inverter in near the sub and cd changer, so does anyone know of the best place to tap into the wiring around that area?
    Ben
    Jun 2003
    World of my own
    9,813
    There's a permanent live on the sub connector you could get a piggyback connector on, but I wouldn't want an inverter powered up when you're not using it, it'll drain the battery (even when the playstation is off). I'd use that live to feed a relay then use the remote on from the HU to trigger the relay, so the inverter will only switch on when the HU is on.
    Alex Turner
    Apr 2008
    Luton
    61
    Yeah that's exactly what I want to do, but which wire is a live when HU on? it's only a small inverter (I mean tiny, not much bigger than the plug it's self) so it can be hiden in between the sub and rear light.
    Ben
    Jun 2003
    World of my own
    9,813
    Depends if you have the Bose system or non Bose.
    Non-Bose system:
    Bose system:
    Alex Turner
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Bear in mind though that IIRC, the sub feed is only 5A rated, so if your inverter pulls more than 60VA, you will pop the fuse. The PS should not pull that, but the inverter may have a switch on surge that could pop it...
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    Apr 2008
    Luton
    61
    excellent pic! cheers mate.
    I don't wanna butcher the wiring to find out it's no good, if ya know what I mean.
    Ben
    g60jet's Avatar
    May 2008
    UK
    147
    If you've got a slim line PS2 you shouldn't need to run an inverter IIRC it runs of about 5 volts after the power transformer. If so, get one of these 12v cigar lighter power adapters that allow you to change the connector and voltage, and run it directly of your cig lighter/12v socket in the boot. If you have one.
    |Present: 2005 B7 Audi A4 Avant 2.0T FSI Quattro S-Line|DIS|Phatbox|Aircon'd Glove Box|Ambiant Light Pack|
    |Gf's Motor: 2003 8L Audi A3 18.T Sport | Standard |
    |Previously: SEAT LEON FR TDI|German Spec Corrado G60 JET LHD|Mk2 Golf Cab|Mk2 Fiesta 1.4s|
    Apr 2008
    Luton
    61
    I don't have a 12v socket in the boot though
    Ben
    g60jet's Avatar
    May 2008
    UK
    147
    Quote Originally Posted by Beenie View Post
    run a lead from the battery and pic up an earth point in the boot.
