Sky InsuranceChris Nott
    Nov 2007
    49
    CD Changer into 2005 A4 (B6)
    I've got a 2005 A4 with a standard concert HU but no CD changer.
    I've got a 6cd spare from a 2000 S3, I presume this will work?
    Also, will the cabling be in-situ behind the glovebox, and if so how do you get to it as a quick look didn't give any clues how you might go about getting behind the glovebox!
    Graham
    Jan 2007
    Hampshire
    1,155
    5 8mm bolts hold the glovebox in. Very doubtful there will be any wiring present unless the car ever had an autochanger fitted before. The changer you have should be OK I think.
    A6 3.0 TDI.
    Nov 2007
    49
    Oops, just realised I meant B7 chassis!
