Sky InsuranceJMB Retrofits
    Feb 2004
    Halifax, West Yorkshire
    79
    Question Anyone got pin-outs for Bose amp connectors?
    Hi All
    [I have a 2003/53 S4 Avant]
    Does anyone have the pin-outs going from the HU to the Bose amp? I need to figure out which are the pre-outs for the sub so I can splice the wires and send the signal to an external amp/sub. Big thanks to AndyMac for the suggestion!
    Thanks all.
    [.:: brixo ::.]
    2008 Audi A4 2.0 TDi 170 S Line SE Avant, Lava Grey, RNS-e, happy to be back to an Audi!
    2007 Porsche Cayman, 2.7 stock lump. Bought the wrong engine. Amazing chassis gone...
    Previous Audis - A3 1.8 SE, B5 A4 1.8T Sport, B6 A4 1.9TDi Sport, B5 S4 Avant, B7 A4 2.0TDI S Line, B6 S4 Avant...
    Jun 2003
    World of my own
    9,813
    Here you go, knew I'd seen them somewhere. Should make life a little easier:
    http://forums.audiworld.com/audio/msgs/53970.phtml
    Alex Turner
    Feb 2004
    79
    Sir, again, you are a star - thank you!
    I have just taken a look at the connector and seems pretty tight in there - I'll start digging out the screwdrivers...
    Next task... trying to figure out how to get power into the rear!! I have never done an install in an Audi (this is my 8th in a row) - they are slightly better made that my 306, Cav, Astra or Citroen!!
    Cheers again.
    [.:: brixo ::.]
    Jun 2003
    World of my own
    9,813
    I took the easy route and plumbed the power cable through the bulkhead via the ECU cover. Just prise the top off and it drops straight into the drivers footwell, there's even a spare grommet on the main rubber boot you can use to keep it watertight.
    Alex Turner
