AH FabricationsChris Nott
Results 1 to 16 of 16
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Factory Aux-in to RNS-e
    I have a new S3 with the Aux input fitted next to the handbrake. I have had RNS-e retrofitted but the guy had never come across an 8P with Aux-in so didn't have the right kit to connect it.
    He told me I should be able to move some wires (he told me which ones) from the quadlock into the 32 pin connector (which I have now purchased) and then use the CD changer option to access the channel.
    If I enable CD changer with VAG.COM I get an error because it cannot communicate with a changer, which I expected to be honest, also of course the CD changer link is disabled anyway so this is not the way to do it.
    I could of course connect an ICElink to the data lines and then connect the channels to the aux feed, but this seems like a bit of a waste of money.
    Is there any way of having an Aux in on RNS-e?
    Or can anyone suggest a cheap way of fooling the RNS-e into thinking a CD changer is connected. I don't like wasting money.
    Many thanks
    Staz
    8P2 S3
    Jan 2007
    Hampshire
    1,155
    You can add the Aux-in to the 32 pin TV connector. You then need to enable the Aux-in option in the RNS-E using VAG-COM.
    A6 3.0 TDI.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by Issac Hunt View Post
    I have had a look through all the options on vag.com and haven't seen an aux-in option at all.
    If I enable TV I just get a comms error like the CD changer one.
    8P2 S3
    Jan 2007
    Hampshire
    1,155
    Change the second to last digit of your RNS-E coding to a 5 or a 6 and reboot it, This should enable the AUX-IN option.
    A6 3.0 TDI.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Ok I'll try that later. Cheers.
    8P2 S3
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Not been able to get online since I tried the other day.
    Second to last digit is a 1 and changing it enables sat radio or digital etc.
    The last digit is a 5 as I have MFSW, a 6 gives TV.
    There is no aux-in option.
    What is the cheapest device for fooling the car into thinking a CD changer is installed??
    8P2 S3
    Jan 2007
    Hampshire
    1,155
    Quote Originally Posted by staz1000 View Post
    Yes there is. Mine is coded 301756 and the AUX-IN option is available.
    A6 3.0 TDI.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Hmmm strange. There is no mention of aux-in on the help bubble and my second to last is defo a 1. I'm in Bavaria right now so I will have to wait for a few days to try it out.
    What button to do press to enter aux?
    8P2 S3
    Jan 2007
    Hampshire
    1,155
    I have the latest version of VAG-COM and it still doesnt show up in the help bubble but it does work!
    Press CD/TV and it will be in the list shown, along with CD, MP3, TV etc.
    A6 3.0 TDI.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I finally tried this out last night but it didn't work. It accepted the coding but would not show the option on the source list.
    8P2 S3
    Jan 2007
    Hampshire
    1,155
    You need to re-boot the RNS-E afterwards. I think your RNS-E will also need a S/W index of 0650.
    A6 3.0 TDI.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    I did re-boot it (simply switch off then on you mean yes?) and my software is 0650.
    I found the ross-tech wiki page which confirms that 5 should be aux-in so I'm finding it a bit strange that it doesn't work.
    8P2 S3
    Jan 2007
    Hampshire
    1,155
    Re-boot it by holding down RADIO and SETUP until it restarts.
    A6 3.0 TDI.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    AHA! I didn't need to tho, this time I left it set at 5 instead of changing it back, so when I just turned the ignition back on it had worked!!
    You're a star Issac!
    Now.....which pins do I need to put where? I know the aux ones from my factory fit aux socket are the yellow (aux gnd), green (Lin) and grey (Rin) ones so where do I put them?
    8P2 S3
    Jan 2007
    Hampshire
    1,155
    You need to connct the 3 wires into the 32 pin AV connector. You can get this connector from Audi if you dont have a media adapter already installed?
    Aux In Left - pin 22 of AV Connector
    Aux In Right - pin 6 of AV Connector
    Aux In Gnd - pin 21 of AV Connector
    A6 3.0 TDI.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    All done now, works like a dream.
    Cheers Issac
    8P2 S3
