Results 1 to 10 of 10
    spannah's Avatar
    Jul 2007
    N.London
    238
    Replacing OEM head unit to a newer unit
    Guys,
    Looking at my OEM head unit and the new one, the OEM looks wider in size therefore the hole must be bigger. What do i do with regards to putting the new one in, as there will be a gap.
    Can anyone advise?
    A3 8L 1.8T 1996
    Jun 2003
    World of my own
    9,813
    What new one are you talking about?
    A new Audi one (which won't work as it'll be CANBUS controlled) or an aftermarket unit.
    If you're going aftermarket then you'll need a fascia adapter to fill the gaps either side, an aerial antenna adapter to power the beesting aerial amp and the rear amp adapter to feed the rear amp & sub from the rear RCA's
    Alex Turner
    spannah's Avatar
    Jul 2007
    N.London
    238
    Sorry i will be changing my standard head unit to a Sony one.
    Where can i purchase the facia blocks and the Bose adapter from?
    What kind of prices will i be looking at?
    DBXdarkangel's Avatar
    Mar 2008
    Torquay
    161
    Quote Originally Posted by spence_star View Post
    here ya go m8ty.
    http://www.nexxia.co.uk/Car_Stereo_f...ts/Audi/A3.htm
    Jun 2003
    World of my own
    9,813
    You'll also need an antenna amp adapter
    http://www.caraudiodirect.co.uk/aeri...tor-p-211.html
    Alex Turner
    Mar 2008
    Torquay
    161
    that is also on the same link i posted.
    http://www.nexxia.co.uk/Car_Stereo_f...a_adaptors.htm
    naefeart_A4's Avatar
    Bonkers
    Sep 2006
    Aberdeen, Scotland
    156
    Quote Originally Posted by AndyMac View Post
    Apollogies for the hijack, but Andy are those the same requirements for the B5 A4?
    Have an aftermarket Sony headunit in my wardrobe, but don't want to mess about removing the rear speakers or running new cables.
    N
    A4 1.8T Quattro Sport | H&R Springs | Milltek Cat-back | Custom Code Stage 1 | 18" BBS RXs | Falken 452s |
    Jun 2003
    World of my own
    9,813
    The B5 A4 just has a rear amp (no sub, unless Bose).
    You'd still need the antenna amp & fascia adapters and either an RCA input adapter to feed the rear amp or new speaker cable to bypass the crappy rear amp (which is bolted to the passenger side rear speaker.
    Alex Turner
    S3_Pricey's Avatar
    Nov 2006
    Worcester/Leamington Spa
    300
    just got a quick question. i have changed the HU in my A3 but did not use an ariel adaptor or a rear amp adaptor. I was just wondering if installing such items would get rid of the buzzing that is pretty much constant through the rear speakers? also where mite i get a rear amp adaptor? cheers in advance...
    S3, 2001 Facelift, 210bhp AMK,
    Jun 2003
    World of my own
    9,813
    If you don't have the adapter then how have you got the rears/sub rigged up at the moment?
    The adapter allows you to plug standard RCA's into the non standard mini ISO connector that Audi use to feed the rear/sub amp. So without it the rears won't work at all, so you must be using something already.
    Alex Turner
