Sky InsuranceAH Fabrications
    Mar 2008
    7
    volume changes with speed
    on my 2001 s4 factory bose symphony system it sounds like **** when its at low volume(almost like a blown speaker) then when you speed up it all of sudden kicks louder and sounds great. what the hell?
    macca's Avatar
    Sep 2006
    Sussex.
    525
    they have a speed pulse input on the stereo called GALA, this can be set on the stereo for the amount the volume is increased.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    Apr 2007
    Staffs
    586
    It could be that you do have a speaker on its way out. A speaker interconnect (or whatever its called... the tiny sliver of wire that runs from the cable connectors, through the cone then down to the magnets) may have partially broken (or have a bad connection), which at low volumes will not sound right. As Macca pointed out, the headunit takes a signal from GALA and increases the volume as you speed up (to try combat external wind/road noise). The increase of power to the speakers may temporarily overcome the fault resulting in the speaker once again sounding clear, but as you slow down the fault will return.
    Does the same happen when your car is not moving and you simply turn the volume up?
    Andymac is probably your best bet to get a better answer on this as he seems to be all knowing when it comes to sound!
    Jun 2003
    World of my own
    9,813
    The door connectors are the most likely culprit. They get "dirty" and need more power to make the connection. Either that or you just need to resolder some of the components on the Bose amp. The solder joints dry out over time and this can cause intermittant cutting out/crackling, especially at low volumes or when the amp is cold.
    Alex Turner
