Chris NottAH Fabrications
Results 1 to 7 of 7
    Mar 2008
    New head unit, but no power.
    Im installing a new pioneer HU into a 2002 TT roadster(with a bose speaker system). Ive got all the correct wiring adaptors, but when its all connected the HU doesn't power on. When I plug the original audi system(chorus) the screen says "safe".
    -the pioneer head unit works fine in another car.
    Any advise would be much appreciated.
    Jun 2003
    World of my own
    9,813
    You need to connect the ignition on feed & perm lives together at the HU (the red & yellow fused wires). Audi's from 01 onwards aren't wired with the 2 seperate feeds needed by all aftermarket HU's. They only have a perm live feed and the ignition on is fed through the CANBUS. Twin the 2 feeds together and it'll work fine but you'll need to turn the HU on/off manually.
    If this is a pain then you'll need to wire in a proper ignition on feed from the ignition or the fusebox.
    Alex Turner
    RUDAZ
    Mar 2008
    Leeds
    17
    sweet, exactly what i wanted to know too, my aftermarket HU was also pioneer. turning the HU off manually wont harm the player/ car in any way or loose battery power, no??
    Jun 2003
    World of my own
    9,813
    No, as long as you remember to do it
    Alex Turner
    fran-s3's Avatar
    1,090
    Would I have the same issue with my 2001 S3 Andy?
    Jun 2003
    World of my own
    9,813
    No way of telling, they changed over to CAN-BUS around 2001, so you'll just have to see when you pull the HU
    Alex Turner
    fran-s3's Avatar
    1,090
    Ok cheers Andy, I have a early Jan 01 plate so fingers crossed!!! (Although I suspect I may have as mine has Sat Nav + which I suspect although im no expert, needs CAN-BUS to operate).
