Badger5Monster Motorsport
Results 1 to 7 of 7
    BigRD's Avatar
    Feb 2008
    Stirling, Scotland
    60
    RNS-E, Kufatec IMA with a Rhapsody HDD Media Player - Anyone fitted this?
    Hi folks,
    I'll be picking up my A4 B7 in a couple of weeks and after a few hours of searching I came across a post over at http://www.rs246.com/index.php?name=...&postorder=asc
    This gives details of an RNS-E using a Kufatec AMI with a Rhapsody HDD Media Player controlled via the RNS/MFSW controls. This would put my complete music collection on a hard drive in the car with a selection of films. Anyone fitted this or something similar?
    "It is in truth not for glory, nor riches, nor honours that we are fighting, but for freedom -- for that alone, which no honest man gives up but with life itself"
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Fitted these plenty of times, but you mean IMA, not AMI.
    BigRD's Avatar
    Feb 2008
    Stirling, Scotland
    60
    You are, of course, correct. Typo
    Which of the Rhapsody players do you find operate best with the RNS-E controls? There appears to be some debate on the 110 and 300 not working properly although they are listed in the latest compatability list. Have you been able to source the RSH-250? It looks nice and compact for fitting in the glove box.
    Also where do you take the power supply from?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I have used the 100's and 300's. I Prefer the 100's as they have a better audio stage (louder) than the 300, the 110 is also OK.
    I have no experience of the 250.
    As for power, well you need a switched live from the fuse box.
    BigRD's Avatar
    Feb 2008
    Stirling, Scotland
    60
    Cheers for the info. Do you find the 110 works fine from the RNS-E? It's the most easily available player in the UK.
    Audi's are new to me so I've a steep learning curve to achieve with regards to the electrics. I'm an electrical engineer and a dab hand with PC's so none of this should be above my capabilities. Can you point me in the right direction as to ignition switched power?
    May 2006
    UK
    233
    Hi
    Looking a doing the same.
    Do you need to enable VIM first ?
    BigRD's Avatar
    Feb 2008
    Stirling, Scotland
    60
    You only need to enable VIM if you want to be able to see the Rhapsody display whilst driving. This is my prefered choice. My IMA cable has arrived so I just need to buy the rhapsody.
