AH FabricationsVolks Autos
Results 1 to 12 of 12
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,071
    Whine through speakers
    When I got my 96 A4 T Sport it came with an aftermarket radio. This has since been binned and I have fitted my trusty Alpine deck. When I connected the magic box to allow me to keep the Audi amp for the rear speakers I got engine whine through them. I have added a nice set of Focal components to my front doors and a pair of 12" Kicker subs in the boot and it all sounds rather nice apart from that damn whine on the rear speakers. I intend on adding an amp to get the most from the components up front and was hoping to just add some better rear speakers to give me some fill and the back seat passengers some melody.
    Any ideas before I just rip it out and run some fresh speaker cables straight from the deck?
    Jun 2003
    World of my own
    9,813
    Errrr rip it out and run some fresh speaker cables straight from the deck is the only way forward.
    Alex Turner
    wallacr's Avatar
    Nov 2003
    241
    I've seen engine whine before when the radio hasn't been earthed sufficiently. My brother has a 98 A4 and he replaced the head unit for a kenwood one and had pretty bad engine whine and all we did was run a better quality earth cable and it did the job.
    Not sure if this will help you, but I hope you get it sorted soon.
    Cheers,
    Rich
    Dec 2006
    barnsley
    1,013
    it could be the earth on the headunit or the earth on the standard amp its more likely to be the earth on the headunit
    personally id ditch the standard amp and rear speakers and put something in which is going to do justice to the focals
    replacing the speaker cable to the rear speakers may just show the inadeqaute earth on the headunit
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Jun 2003
    World of my own
    9,813
    The issue is the feeble pre-out cable Audi use, nothing to do with the HU or the amp. The low level pre-out cable is not shielded properly at either end, so will pick up alternator whine.
    If the fronts running off the HU don't whine then it's not an earth issue, and rewiring the rears will solve the problem.
    Alex Turner
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,662
    Sure you haven't got a James Blunt CD in the head unit?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    I have this problem in a previous car and it turned out to be a bad earth
    Skint because of my car, the forums made me do it
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,071
    Quote Originally Posted by AndyMac View Post
    CheeRS mate.
    Next question for the weekends job, how big are the stock speakers as I have a set of 6" Infinty 2 ways kicking about here?
    Jun 2003
    World of my own
    9,813
    The stock fronts are 4" and you only have 55mm depth to play with which includes the fitting adapter, so wave goodbye to your Infinitys I'm afraid. You'll need 5.25" slim components.
    Alex Turner
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,071
    I've already got my 5" Focals in the front. It's the back speakers I'm having problems with. Also have some 5" Kenwood Dualmags somewhere.
    Jun 2003
    World of my own
    9,813
    Ahhh, sorry, the rears are 6.5" coaxials, but again you need fitting adapters and need to remove the cover on the back shelf for access.
    Alex Turner
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Agree with Andy, I've had the same problem (still do, been too lazy to get it sorted)
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
