Badger5EM Tuning
Results 1 to 9 of 9
    fran-s3's Avatar
    1,090
    Random Vibrating Front Door Speaker?!
    Hey chaps,
    Have the full bose setup and am loving it so far! (I know a lot of people don't but I must say what an improvement after having a normal setup in a golf!)
    Have a strange annoyance though, my drivers side front speaker vibrates on certain ranges it's bizzare... (and ruins the song) Like on some of my muse tracks when theres a low frequency sound like there's a 1p piece in it - it's just my front driver speaker that does it all the others are fine!Tried tapping it a few times haha but nothing...
    Thinking of taking the door card off and having a peep, anyone come across this before? Any advice of what may be causing it appreciated, its fine on all the other ranges of music..
    Cheers!
    richjohnhughes's Avatar
    Oct 2007
    104
    empty the door pocket and make sure nothing is moving around.
    otherwise, maybe a lose screw / or you have blow the speaker.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Sounds like you've blown the speaker as I had exactly the same problem. I ended up replacing mine in the end (but it took me nearly a year to find one second hand). They are 100 each from Audi.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    fran-s3's Avatar
    1,090
    Thanks for the super quick reply guys! 100 each, yikes that's audi parts isn't it for you! Hoping its not blow as it works fine on most othe frequency will try clearing the door pocket and taking off the door card and tightning the screws....
    Is it hard taking the door card off.... anyone have a procedure handy?
    Jun 2003
    World of my own
    9,813
    You can pick up a replacement on ebay if it is blown.
    Removing the door cards is pretty easy. First lower the windows, then remove the 2 visible screws at the top on either end of the door card, remove the single screw inside the grab handle, push down the plastic cuff inside the grab handle and remove the 2 screws behind it. Pull the whole door card straight up and out, but not too far as you need to unhinge the door release cable and unplug the wiring looms.
    Alex Turner
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Jason
    fran-s3's Avatar
    1,090
    Awesome thanks chaps!
    Lastly Andy, do you have any links or part no.s o I can search for on ebay? I need a bose front door speaker, not sure if there different to standard a3 ones (surely they are) ?
    And finally do they just unscrew out and screw the new ones back in place obv after you've plugged them in? You dont have ro buy any additional adapters or drill out rivets do you replacing like for like?
    Cheers gang!
    Jun 2003
    World of my own
    9,813
    Don't know the part number, but basically Bose only produce one 4" speaker, I think it's the same unit used in their sub woofer and possibly the same driver used in their 802 PA speakers.
    They look like this:
    http://cgi.ebay.co.uk/BOSE-802-SPEAK...QQcmdZViewItem
    Replacement couldn't be easier, just 3 bolts remove & replace.
    Alex Turner
    fran-s3's Avatar
    1,090
    Smile
    Sorted! Thanks guys, yes was the speaker that was knackered! (after 7 years one was bound to go)
