Volks AutosEM Tuning
    41
    Desnsion 100 Installation - Help!!!!!
    Hi all,
    I've just purchased a Dension 100 unit to go in my A6 Avant.
    On the supplied adapter there is what appears to be a loose earth(it's black) cable that i can only assume needs to be connexted up to something. There's nothing in the instructions relating to it.
    I've read elsewhere that this needs to be connected to the chassis of the head unit. Is this correct? If not what should i do with it.
    All help greatly appreciated!!!!
    Thanks in advance,
    Andy
    Feb 2005
    london
    51
    that's right, you should of got some instructions in the box, there's a paragraph that talks about attaching the balck wire to the chassis
    cheers
    migzy
    41
    Cheers!!!
    That's done the trick!
