Badger5Volks Autos
Thread: A4 Sub
    Feb 2008
    Bristol
    A4 Sub
    Before I start taking bits apart on my A4 2001 can someone tell me where I might find the standard amp & sub ?
    It it's not broke don't try to fix it.
    Dec 2006
    barnsley
    1,016
    if its a b6 a4
    and if it has the bose system installed it will be in the right hand side cubbyhole
    look for a big black plastic moulding with a tiny grey amplfier on it
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Feb 2008
    Bristol
    I have found the sub which is under the parcel shelf facing into the boot, Should there be anything else ?
    Feb 2008
    Bristol
    Ok Amp now found I have Replaced with 750w 3 way amp running rear speakers and two 10 inch subs in a box.
    Much nicer clear sound and more bass than I would need.
    Feb 2008
    West Yorkshire
    Hi,
    am looking to do a simler setup on my audi a4 can you tell me what you did as for wiring amp!!! did you by pass old amp!and where did you get the remote feed ... does it thud when switch on!!
    cheers mate.... Ole.t
