JMB RetrofitsVolks Autos
Results 1 to 8 of 8
    fran-s3's Avatar
    1,090
    S3 Factory Sat Nav Question
    Hi all,
    I'm in the process of buying an 2001 Audi S3 which has the integrated Sat Nav system which is cool. Although im a complete novice to all this, and wondered how good it really is compared to my tomtom GO I currently use...
    The chap had the original Audi CD from 2001, so its not updated version... So I was wondering is it as simple as purchasing a new updated CD and popping it in?
    Also can you do postcode searches i.e navigate to a postcode, and can you get speed camera locations for it? He said you couldn't on his version but wasn't sure if the any new versions support this, so does anyone know? If not I'll keep using my tomtom! :L
    Also it has the option to have a TV installed, any ideas how much wonga is needed for this? If it's sily money i wont bother.
    Many thanks for your time.
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    Depends if you class £700 ish for TV as expensive !
    Gone A3 TDi S Line DSG Bluefined
    Now Seat Leon Cupra about to be Bluefined
    fran-s3's Avatar
    1,090
    Quote Originally Posted by SteveTDCi
    Depends if you class 700 ish for TV as expensive !
    Flip me err yes I do! Thought it would be a case of buying a tuner and installing, hmm ok thanks for that!
    Do you know if the audi sat nav system can navigate to postcodes, or is there anyway of updating them to? Mine reads from a cd-rom disc on a dvd if that helps narrow down which one it is?
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    no idea, I think it only takes partial postcodes. The £700 price is for the Audi tuner, you could probably go aftermarket but I would think you are still looking at £300ish + fitting. I think you can upgrade to the DVD system but it does mean a new ubit, they start around £500 I'm sure there is a post on here about it.
    lil_coz's Avatar
    Nov 2007
    1,636
    You put in the first 4 digits of the postcode and then you start entering the road name. It'll have a list of all the roads that have the beginning of the postcode. when you pick your road, you enter house number and off you go! As far as I know they dont pick up speed cameras.
    Coss
    fran-s3's Avatar
    1,090
    Quote Originally Posted by lil_coz
    Coss
    Great stuff cheers for that, is that for all the systems in general whatever edition?
    Oct 2003
    up north...
    767
    all the current audi rns-d and rns-e maps only do 4-digit postcodes but its not usually a problem
    the correct tv module can be retrofitted -its quite cheap from ebay or ebay.de, you need the module (usually £150-180), some sort of tv antenna system (the oem factory system uses a different aerial diversity switcher box at the back, different tv capable amps (there are 3 or 4 of them hidden around the rear screen) and a wiring loom to connect it to the back of the satnav unit, then recode the satnav with vag-com or similar.
    i wouldnt bother, but you could consider a tv-in module for your satnav and an aftermarket dvd player/tv instead - although you lose the head units control of the tuner if you go this route - you'll end up with a remote infrared for the dvd/tv
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    fran-s3's Avatar
    1,090
    Quote Originally Posted by dunk
    the correct tv module can be retrofitted -its quite cheap from ebay or ebay.de, you need the module (usually 150-180), some sort of tv antenna system (the oem factory system uses a different aerial diversity switcher box at the back, different tv capable amps (there are 3 or 4 of them hidden around the rear screen) and a wiring loom to connect it to the back of the satnav unit, then recode the satnav with vag-com or similar.
    Great stuff cheers for that, sounds like a plan!
