Sky InsuranceEM Tuning
    Aug 2007
    48
    A3 8P with Bose (Downgrade!) Best place for Headunit earth
    Getting a horrible amount of interferance from my aftermarket HU when the lights/indicators are on. This gradually increases with the revs of the engine. I've read that it's best to change the OE earth for a better location. The 8L being behind the glovebox. Does the same tactic work for the 8P.
    Jun 2003
    World of my own
    9,813
    Should do, worth attaching an earth lead to the HU chassis and then with the engine running and the HU on try out different locations behind the glovebox to get the best result. No guarantee it'll get rid og it completely so you may need to use a ground loop isolator on the RCA's of the new HU.
    Aug 2007
    48
    Cheers Andy,
    How would i wire a ground loop isolator onto the RCA's? Take a feed of the Autoleads convertor?
    Jun 2003
    World of my own
    9,813
    Between the HU and the adapter, GLI's normally have RCA in, RCA out
