Volks AutosEM Tuning
    Oct 2007
    cork ,ireland
    73
    wiring harness for rnse
    hello all
    does anyone know wher i get a wiring harness for an rnse that includes the blue tooth plug and microphone wire
    thnks
    c
    a4 v6 2.5tdi b6 18"rs rns-e genuine bt quattro chipped to 210hp mfsw,cruise control, ashtray ipod connector,
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    http://www.kufatec.de/shop/index.php
    You should be able to find everything you need there.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    Oct 2007
    cork ,ireland
    73
    kafatec
    thanks marm
    but i tried them already they dont have the one i want
    thanks anyhow
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Quote Originally Posted by quattrov6tdi
    thanks marm
    thanks anyhow
    I'm sure if you talk to them they will make you what you want.
    They have the RNS-e adaptors and the Bluetooth harness available to buy on there site. Just ask them to combine the two.
    Personally I'd just buy both items and splice them together myself as there are only four wires from the bluetooth that go to the RNS-e.
    I think if kufatec don't make what you want then you'll struggle to buy it anywhere. Alternatively, buy the looms and i'll put them together for you.
    Oct 2007
    cork ,ireland
    73
    wiring
    thanks again marms
    could u tell me where i splice each wire because i think that could be my prob...that i have wired wrong .........you see my vagcom cant find my bt unit. i had 5 wires can l,can h,k-line ,earth and supply .if u could tell what pins they go in at the back of the rns-e i would be grateful
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    thanks again marms
    You should find all the info you need in the following pdf file
    http://www.nsxjr.com/docs/RNStoSym2.pdf
