Monster MotorsportChris Nott
    S3 chj's Avatar
    Nov 2007
    South Wales
    296
    fitting a amp wiring kit in a3
    hi guys and girls im trying to fit a amp in my a3 but cant see an easy way of getting the + lead through the engine bay and in side the car, is there a easy way of doing this, can anyone give me some advice please
    cheers chris
    Jun 2004
    Surrey
    595
    On the passenger side by the pollen filter you will see a rubber grommet. Just push a coat hanger through it to make a hole and you can push the cable through.
    You may find removing the 8 torx bolts for the glovebox easier so you can find the cable. Under the bonnet you will see some trunking to run the cable in to the battery but I think you need to remove the air filter box to get to it properly.
    S3 chj's Avatar
    Nov 2007
    South Wales
    296
    how far under the dash will the cable come through,i havent found the pollen filter yet will have a look tomorrow, thanks mate
    Jun 2003
    World of my own
    9,813
    The cable comes through behind the glovebox.
    You'll need to remove the glovebox and then it's easy.
    The pollen filter is under the passenger side wiper, near the front passenger wing.
    S3 chj's Avatar
    Nov 2007
    South Wales
    296
    Quote Originally Posted by AndyMac
    thanks mate i know where to look now
