Volks AutosMonster Motorsport
Thread: RNS-D TO RNS-E
    Sep 2007
    Herts
    11
    RNS-D TO RNS-E
    Hi, I have 2001 facelift S3 with Rns-d fitted from the factory (import). How difficult is it to change to an Rns-e. Any suggestions would be most helpful. Thanks
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Fairly easy I would imagine, I did this with my A4.
    Check www.navplus.us. There are instructions on there.
    53 A4 2.5TDi Quattro Sport 180 Tiptronic. Heated Buffalino leather, DVD Sat Nav RNS-E, TV, Bluetooth, 6 cd, BOSE, Colour DIS, Cruise Control, Auto lights and mirrors, Interior light pack, Heated mirrors.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    As they never made the RNS-E for your year/shape of car then it is not as simple as young Arthur makes out.
    Basically buy and A4 and trim to size, remove the metal strip at the bottom of the A4 unit, add a 2mm strip of metal at the top to hide the gap.
    Bypass the TMC unit to join the two different canbus types together.
    Pickup the canbus from the 26 pin connector and patch into the RNS-E harness.
    If you have TV tuner in the boot, then swap it for a revision "C" or "D" module.
    Sep 2007
    Herts
    11
    RNS-D TO RNS-E
    Cheers guys, another question for you. Does my car have all the relevent wiring for the rns-e and will I need to use vag-com to reprogram it. I know nothing about wiring but I am capable of trimming the unit to fit.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    No it doesn't have all the relevant wiring, you will need several adaptors.
    Yes you will need VAG COM
