Results 1 to 10 of 10
    Red Head's Avatar
    Flat Out
    Nov 2007
    Belfast
    64
    Exclamation Aftermarket Head Unit Means Rear Speakers Are NOT Working
    Hi!
    I have a 2003 8P A3 TDI Sport with a Concert sound system. The car has an aftermarket Kenwood head unit and when adjusting the fader to the rear, the rear speakers are not working at all. Is there an adaptor that is required to make the rear speakers work with the Kenwood head unit? It sounds terrible with only the front speakers working and therefore no bass at all....
    I tried an adaptor from Halfords and it seemed to be faulty as the PCB within the adaptor did not seem to house any components, even the Halfords guy was confused!
    Can anyone shead any light on this mystery?
    Jen
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    There could be about 4 different wiring looms. There's normally 1 for standard system, 1 for rear speakers amped, 1 for all speakers amped and another for bose. Check the autoleads website you may have the wrong wiring loom in there.
    Built in Germany, Perfected in England
    Jun 2003
    World of my own
    9,813
    Yes you need an RCA input adapter (Autoleads PC9-401), there are no electronics in it it's just a wiring adapter to take the standard Kenwood RCA's down to the non standard Audi plug that feeds the rear/sub amp. The reason it didn't work is probably because you didn't connect the remote on lead to the power antenna/remote on lead on the kenwood, so the Audi amp didn't get the trigger to tell it the HU is on, so didn't power up.
    Even the Halfords guy was confused? That's not really saying a lot is it, they generally get confused when they see someone driving anything other than a Saxo.
    Red Head's Avatar
    Flat Out
    Nov 2007
    Belfast
    64
    Yea the Autoleads PC9-401 was the adapter that was used, trying again next week when a new adapter comes in but will ensure your instructions are followed, thanks!
    Red Head's Avatar
    Flat Out
    Nov 2007
    Belfast
    64
    Still no joy, the wires at the head unit and wires at the amp in the boot are all working ok so I will have to pay a fortune and go elsewhere that specialises in ICE
    Turbo Petrol to Turbo Dervvvvvvv
    karl7900's Avatar
    Nov 2006
    1,402
    I'm in Bangor if you want me to have a look at it for you. I've fitted CD players to my last 3 Audis and never had a problem. Just fitted a new Alpine head unit to my A6 a week ago so I have a spare head unit (Pioneer) sitting here that could be connected to your car to check if its the Kenwood or the car at fault.
    Red Head's Avatar
    Flat Out
    Nov 2007
    Belfast
    64
    A mate who works in Halfords tried a Sony head unit and the same thing happened, no rear speaker volume, he has fitted head units to plenty of audis before... The tiny sub is definitely in the boot, and is connected, so its probably the car. Vag can brought up a fault of the audio system. A real head pickler!
    Jun 2010
    Did you find a fix?
    Quote Originally Posted by Red Head View Post
    Hello, I know it's a while ago but did you get a fix for this? I've just tried installing an aftermarket unit in mine and my rear speakers are really low and very selective in what frequency they throw out.
    Kish
    Red Head's Avatar
    Flat Out
    Nov 2007
    Belfast
    64
    Quote Originally Posted by kayvee View Post
    Kish
    Hi,
    I sold the Audi last year and never found a cure at all for the rear speakers! The car had an aftermarket Kenwood headunit which was part of the problem. The car was meant to have a Concert head unit as standard but the woman before me installed a Kenwood headunit and the rear speakers were therefore not working when I even bought the car!
    Jun 2010
    It seems wiring the rear speakers directly to the headunit's amp is the way forward then
    thanks red head for getting back to me
