Sky InsuranceChris Nott
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,852
    A4 B6 HEADUNIT--??
    Hi,im fitting an aftermarket headunit to my car,well dvd 7'' screen,before i actually go ahead fitting it,i decided to see how it would look ......ive took the original chorus headunit out,put new (aftermarket) one in..theres a big gap left,obviously the chorus headunit is a lot wider,what do i do now?what have you guys done/used after fitting aftermarket headunits?
    Dec 2006
    barnsley
    933
    there are several trim panels available to finish the dash how you wish
    some are double din some are single it all depends on what you have fitted and the desired finish
    any good car audio shop should have them in stock or at least be able to order them for you
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Jun 2003
    World of my own
    9,813
    For single DIN I just used the Maystar surround from caraudio direct:
    http://www.caraudiodirect.co.uk/audi...tor-p-662.html
    Matches and fits very well.
    You'll also need a rear amp RCA input adapter and an antenna amp adapter. There is no switched live on the loom either so you'll either need to wire one in, or couple the ignition live to the perm live and switch the HU on/off manually.
