Completed my Zune install today, thought I'd share a few pics and see what you guys thought
Was going to do a full install/write up but it was so simple I couldnt really see much point!
[URL="http://i21.photobucket.com/albums/b294/gixer_1000/two.jpg"][URL="http://i21.photobucket.com/albums/b294/gixer_1000/two.jpg"][/URL][/URL]
Started off by popping out the glovebox and RNS-E, connected up the Dietz 1417, only 4 wires required - can hi/low, 12v+ and earth, ran a switched ignition feed from the rear of the fusebox at the drivers side to provide power for Zune dock and IR extender I installed so that you can use the Zune's remote with the glovebox in the closed position.
[URL="http://i21.photobucket.com/albums/b294/gixer_1000/one.jpg"][URL="http://i21.photobucket.com/albums/b294/gixer_1000/one.jpg"][/URL][/URL]
Next fed the IR extender wire under the centre console and fixed it above the ashtray, was thinking of recessing it into the climate panel but decided against making irreversible holes in expensive panels!
[URL="http://i21.photobucket.com/albums/b294/gixer_1000/three.jpg"][URL="http://i21.photobucket.com/albums/b294/gixer_1000/three.jpg"][/URL][/URL]
Then fed the AV cable through the rear of the glovebox along the with IR cable and Zune dock power leads, connected to the Dietz and re-fitted the the glovebox and RNS-E and fitted the Zune and its Docking station into the glovebox
[URL="http://i21.photobucket.com/albums/b294/gixer_1000/four.jpg"][URL="http://i21.photobucket.com/albums/b294/gixer_1000/four.jpg"][/URL][/URL]
Also coded the RNS-E to enable VideoInMotion so the screen still stays on above 5kph. Sound quality is just like CD's, with the added bonus of full track names on screen and movies as well, Ideal solution for me.
