JMB RetrofitsBadger5
Thread: Audi A4 Bose EQ
    Nov 2005
    Midlands
    215
    Audi A4 Bose EQ
    Hi,
    I currently have bose in my A4 (B6). The system is great, but I find there is no control for the bass. Adjusting the bass level makes no difference.
    I have looked at the soft coding via vagcom and my factory soft code was 01201. To switch off the BOSE EQ, I have reprogrammed the coding to 01011.
    Now I don't get the BOSE logo when the HU is switched on which I beleive is correct if the BOSE EQ is disabled.
    Coding was done via http://www.ibiblio.org/tkan/audi/radios/symphony2.html
    Have I used the correct soft coding?
    Should I have used 01001 soft code?
    Jun 2003
    World of my own
    9,813
    The coding is purely cosmetic, to get rid of the hideously flat Bose EQ you need to pul the HU and chop the earth lead going to the Bose pin on the black power connector.
    Nov 2005
    Midlands
    215
    It must be my ears because when I changed the soft coding the music sounded different.
    The coding I used has some implication on the way the speakers work. I have set the speakers as non-passive (bose).
    I will try snipping the cable.
    jase0851's Avatar
    Oct 2004
    yorks
    782
    vinesh your quick youve only ad the car a few weeks and your into vag-com mods already lol
    EBONY PEARL 2003 1.8T SPORT GMBH 190 AVANT 19" GALLARDO,S S4 SILVER SILK NAPPA HEATED RECARO,S MATT ALI MIRRORS,O.CT INTAKE PIPE, B7 DTM VOTEX SKIRTS, HYPERBOOST HX DIVERTER VALVE, RS4 DOORCARDS+TRIGGERS, AUTO-DIMMING REAR VIEW MIRROR, RS4 BRUSHED ALI TRIM, RS4 START BUTTON, PIPERCROSS PANEL FILTER, RIEGER INFINITY FRONT BUMPER:: NOW REMAP,D TO 240 ISH BHP OMG WHAT A DIFFERENCE
    Jun 2003
    World of my own
    9,813
    Yes, you can change the EQ settings on some Audi HU's, but to get rid of it you need to chop the cable.
    igf
    Best of all, I'm new here but I wanted to ask, if it came with the configuration
    ----> 01201 XXX? X is 0 for no and 1 for bose bose??
    Greetings.
