bonerp
Hi,
Ive bought a dvd player to replace the concert HU in the car. I've purchased the adapter to plug and play, but its not playing!!!
When I turn the ignition off, the stereo stays on. When I turn the stereo off it only goes to standby.
I've checked all the audi wires but none seem to switch when I turn the ignition.
I think I read something about adding an accessory line to the ignition switch, however due to the stupid fixings on the steering cowl, I cant get it undone! So is there anywhere else I can wire it to? After spending 3 hrs on it i'm geting desparate!
Finally, the local sextons said I can just use the aerial straight into the stereo, however its a fakra jobbie. Im guessing I should use the plug, not the aerial. Does this mean an adapter is required?
thanks in advance. Wish I hadnt bothered now.
Paul
Just found this and assuming its the problem of power, and the solution!!!
http://www.audi-sport.net/vb/showthread.php?t=35875&highlight=accessory+switch
Paul
