Chris NottBadger5
Results 1 to 10 of 10
    rpadam's Avatar
    S3 Raj
    Sep 2004
    London
    14
    RNS-D Sat Nav Help
    I've got a slight issue that I hope someone can help me with. I’ve fitted an RNS-D sat nav unit in my S3, think I have an A4 unit as it doesn’t fit in the cage properly.
    Firstly my passenger side rear speaker is just buzzing away and my sub in the rear is hardly making any noise, any ideas?
    Secondly, can anyone (London based) fit my TMC unit and get the FIS display to work?
    Thirdly, does the unit need programming with VAG-COM?
    Any help gratefully appreciated.
    Cheers.
    S3 Raj
    Facelift 2001 Audi S3 - Silver, Aluminium Mirrors, Centre Arm Rest, Sunroof, Full Black Leather, Sat Nav
    Jun 2004
    Surrey
    595
    A4 unit will not fit properly.
    I am sure you need to tap into the CAN bus to get the TMC to work but I am unsure.
    It will need reprogramming for it work correctly.
    Just wondering why you didn't fit the RNS-E? I am near J9 M25 if you fancied a ride out to see me...glad to help a fellow AS member.
    rpadam's Avatar
    S3 Raj
    Sep 2004
    London
    14
    Got the unit really cheap thats why i done the install. Might take you up on your offer but first i need to get the TMC cables, any idea apart from ebay site?
    Feb 2007
    22
    If you have not already seen it, there is loads of good info on tha attached web site. I got a TMC cable for my A2 from a guy called Ralf Deventer who advertises on the German e.bay site. He also sells TMC modules if you don't already have one. You will need to use vagcom
    http://www.nav-plus.com/instructions/
    Cheers Spike
    Cheers Spike
    Jun 2004
    Surrey
    595
    What radio have you got? Are you local?
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    www.kufatec.de do all the cables and stuff for RNS-D TMC
    Have a look at the guide posted above as this is what i followed when I fit mine in my 8L S3.
    Everything worked, you cant get TMC unless you have a new disc version and a TMC unit is needed in order to get the instructions on the DIS.
    A A4 version will fit but needs trimming very carefully down as my unit was a A4 one and fit perfect after some trimming.
    You definately need to recode both the car and the sat nav unit in order to get it to work properly and tell the unit what car its in etc, tyre size needs to be programmed to for correct speed pulse and accuracy of the nav guidance itself.
    Have you taken the speed signal from behind the instument cluster as you need to do this before it will work too?
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Jun 2004
    Surrey
    595
    Gala should be in connector III pin 1. You would need to tap into middle grey connector behind cluster pin 5 for CAN H and pin 6 for CAN L.
    Jun 2004
    Surrey
    595
    I have a genuine VAG-com setup if you want me to do the coding.
    rpadam's Avatar
    S3 Raj
    Sep 2004
    London
    14
    Thanks for all your help!!
    I've changed from concert to the Nav Plus. I'll order the cables today & Steve i'll take you up on your offfer when i get everything together i'm based near Wanstead, London.
    Jun 2004
    Surrey
    595
    Quite a way out maybe someone might be nearer or if you come along to the Cobham meet in a couple of months.
    Send me a PM with you mail address as I have something of use.
