AH FabricationsEM Tuning
    A3steve's Avatar
    Sep 2006
    126
    Symphony II replacement
    Hi,
    Can a A6 unit be used to replace an A3 unit?
    I know its to big, but if it could be trimmed down a bit would it work?
    Potential Issues other than size, would be whether the unit needs to know its fitted in an A3 not the A6 and changing between Bose/non bose?
    can these parameters be altered with VAGCOM?
    Reason for this is i've been offered an A6 version for free and the one fitted in car has seen better days
    Thanks in advance
    Steve
    Jun 2003
    World of my own
    9,813
    Not sure if it'll fit but will certainly work, Bose is selected on the wiring loom not via VAGCOM, so should be a straight plug & play. The only possible issue is the CANBUS. Newer HU's rely on the CANBUS to tell the HU when the keys are in the ignition, so if the new HU is a CANBUS model and your car isn't then the HU will only stay on for an hour then switch off.
    You can get a CANBUS emulator but they're about £90.
    Obviously you'll need the 4 digit security code.
    A3steve's Avatar
    Sep 2006
    126
    Cheers Andy,
    I had totally forgot about the bloody Canbus - need to check, It has the code at least.
    Regards Steve
