Badger5Sky Insurance
    bena3turbo's Avatar
    Genuine Dude
    Oct 2006
    Wirral
    90
    head unit stuck in safe mode
    hi guys,
    i went away on holiday, and, being the idiot i am, i left the interior light on and flattened the battery.
    The problem I have now is the head unit wont let me enter the code. I've read through the concert manual, but no joy. None of the buttons respond. When I press TP and RDS to enter the code, nothing happens!
    I've disconnected the battery and the head unit and tried it again several times.
    Is there anything else I can do? The silence is deafening
    Go banana!
    Jun 2003
    World of my own
    9,813
    Turn the ignition on first then press & hold TP & RDS until 1000 displays. You have to hold them quite hard.
    The use the 1-4 keys on the radio to enter the 4 digit code i.e. 6789 would mean pressing the "1" key 6 times then the "2" key 7 times etc when the code is correctly displayed on the radio press & hold TP & RDS again until the radio comes on.
    You have to do it with the engine running or with the ignition on as sometimes it doesn't work properly otherwise.
    bena3turbo's Avatar
    Genuine Dude
    Oct 2006
    Wirral
    90
    Yeah I've tried that about 20 times now Andy and nothing happens. It's as if its crashed, stuck on the safe mode and nothing is functioning. I only got it a couple of months ago as well, grrr :@
    Go banana!
    Jun 2003
    World of my own
    9,813
    Have you tried it without the ignition on/engine running?
    Alternatively you need to unplug the power on the HU and wait 2 hours then try again.
    Feb 2007
    22
    Hi bena3turbo
    Not sure which type of head unit you have but on later model radios you need to press and hold the RDS and SCAN buttons until 1000 appears.
    Cheers Spike
