Sky InsuranceAH Fabrications
Results 1 to 7 of 7
    Dec 2005
    london
    196
    retrieving code or decode audi stereo
    hi
    I've just bought a 2000 a6 with standard cassette player but the previous buyer didn't have the code.
    it works perfectly so once I've installed my ice i want to sell it but obviously need the code.....
    how do i go about getting the code or how much should i be paying for someone to decode the unit?
    cheers
    Dec 2005
    london
    196
    the unit is the single din concert
    S4 Avant 4.2 V8 :)
    Jan 2007
    9
    Radio code
    Hi,
    I just had a similar situation after getting my dension gateway installed (didn't work - different thread!) but didn't have the radio code. After calls to both the original supplying dealer and my local dealer the code wasn't on their systems so I had to go along to the service department, they plugged in the computer and were able to retrieve the code. Fortunately they didn't charge me for this.
    So if you can find the original dealer worth it's a call but failing that could be a quick trip to the gararge for you.
    Chris
    Dec 2005
    london
    196
    was this done via vag-com as i have it on my laptop?
    S4 Avant 4.2 V8 :)
    Jan 2007
    9
    Didn't see it done as the car was taken into the workshop, but certainly worth trying with Vagcom I would have thought.
    snapon's Avatar
    Jul 2012
    36
    Vagcom can't retrieve stereo codes this can only be done by the main dealer
    27,096
    5 year old thread mate, bit late reply
