Volks AutosChris Nott
    Oct 2006
    24
    Phone audio play through
    Hello
    I'm about to install a Nokia car kit.
    I intend to use the MUTE connection in the power block but I'm unsure about the connections to play the audio through the headunit.
    I'm thinking maybe one set of NF- and NF+ in the block on the right but I'm just guessing.
    It's a concert headunit. Heres the label:
    Dec 2007
    Hi,
    Did you ever do this install? I've just bought a Nokia CK-15 and I'm going round in circles with the leads that I may or may not require... I've also got the Audi Concert (pre 2001) and would like the mute to work automatically and quite like the idea of the sound coming out of the speakers. I'm guessing it's not as simple as connecting to the NF pins, bound to need an interface lead!!
    I'm just wondering what you ended up doing.........
    Simon
    Dave B's Avatar
    REALITY?.... WHERE AM I AGAIN?.... WHO AM I AGAIN?
    Apr 2007
    Oxfordshire and Sofia
    176
    I have done this on my concert today 03 S3 and the only issue is its quite quiet, Works straight off though!
    Dave
    Silver S3 OE03, PH sticker in Rear Window,
    Dec 2007
    11
    turn it up on the stereo and it will get louder, if that does not work long term, try looking in the setup menu and there will be a tel volume, and you can also choose which speaker(s) it comes out of
