Chris NottSky Insurance
Results 1 to 10 of 10
    Aug 2007
    48
    A3 (8P) - Bose Sub?
    Evening everyone, first post here!
    I've got an A3 (8P) and have opted for the the Bose upgrade, ive already changed the Headunit for bluetooth handsfree model, now i'm looking to add a bit more bass to the system, in the form of a decent sub. Question is, does the Bose upgrade on the 8P come with a sub in the back quarter like the 8L did? If so, how do i go about disconnecting it?
    Also another slight annoyance with my new headunit, i'm getting a lot of electrical interferance when the lights/indicators are used, which generally gets louder, the faster the engine revs. Does the standard Bose headunit have a heavy duty supressor or something?
    Jun 2003
    World of my own
    9,813
    Yes the 8L has a sub just like the older model. It's in the left rear cubbyhole, just unplug it.
    How is the new HU connected to the Bose amp?
    You can either use RCA input or speaker input. Speaker input uses a hi-lo converter to bring the signal back to pre-out level and can cause interference. Having said that the RCA method is not without it's problems. It's not the HU it's the bizarre input stage on the Bose amp.
    Either way I'd start with strapping a decent earth lead to the chanssis of the HU and ground it somewhere good behind the glovebox as the Audi earth is pretty feeble.
    Aug 2007
    48
    Ahh nice and hidden away there then, will have a look at getting that removed/unplugged when i get a new sub. I have no idea how the New HU is connected to the Bose AMP tbh, i know the new wiring harness was adapted for the Bose set up, and incorporated RCA's so that must be it.
    I'll start with a better earth and see if that makes any difference
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    That looks like my picture above ?
    The Bose amp is rather feeble too and behind the oposite panel.
    In the end as the space isn't there for anything decent I left mine in situ ( safe enough place to store them as any) and went IB with a couple of 7" sub in place of the rear speakers.
    The amps are in the spare wheel well and I carry a couple of cans of tyre moose.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    Aug 2007
    48
    Good plan, i was thinking of removing that sub entirely, removing the spare wheel and putting some kind of sub in there. Anyone done something like that yet?
    Haven't been able to find any custom boxes which is pretty lame.
    Aug 2007
    48
    Dec 2006
    barnsley
    928
    ive made a custom enclosure for my wheel well
    but unfortunatly cant post pics
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Stockholm
    Aug 2007
    47
    Quote Originally Posted by AndyMac
    Im guessing you mean that the 8P has a sub just like..
    Do you know if the connector for the sub still has the same wireing?
    Most of the ICE installers Ive spoken to seem to have no idea.
    Theyve told me to wipe out everything - but I like the bose sound.
    And the HU with steering wheel remote.
    I just want a little bit more bass.
    You should contact Autoleads and make them produce the AndyMac S3 > RCA sub connector /w remote.
    Feb 2007
    Hampshire
    1,654
    Quote Originally Posted by Stockholm
    The Bose Sub is powered by the Bose Amp behing the trim panel on the otherside of the car. So on the 8P the sub only has speaker level connections.
    You wouldn't believe how small the 6 channel Bose amp is.
    Paul
    VCDS HEX-USB+CAN
    Jun 2003
    World of my own
    9,813
    So you'd need to pick up the pre-outs going to the 6ch Bose amp and use these to feed the new amp/sub
