    Jun 2007
    RNS-E Software update
    I've got an RNS-E (Not sure which software version but it's running a 2005 nav disc), I borrowed a copy of the 2007 disc to update the firmware. I put the DVD in and it seems to recognise it because it says 'Software update disc 0550' when I lower the screen but it says 'Insert nav disc' on the nav section. How do I load the DVD to update the firmware?
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    it should run the software update as soon as you install the 2007 dvd...BUT if you have a 2005 dvd it won't work once you have installed the SW0550 software on the 2007 disc
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    Jun 2007
    Probably a good thing the update didn't work then!
    Just out of interest, what are the differences in software between 2005 and 2007? I'll buy the update and maps disc if it's worth the update.
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Map updates and the inclusion of TMC
    Not sure but I think it calculates routes faster.
    TMC is the information received via radio regarding traffic delays etc. Can be useful if you travel on major routes and motorways as it will automatically divert you around potential hold ups.
    Apart from that I didn't see a lot of change from the 2006 disk I originally had. I got my 2007 disk under warranty via the free upgrade program (even thought I retro fitted my RNS-e)
    Not sure that it is worth the £200 odd they are asking for a new disk.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    benw123's Avatar
    Oct 2004
    Herts, UK
    1,863
    I've also noticed the minor roads are shaded in grey which was different to the 0460/2006 DVDs, but that's it really. TMC rocks - extremely useful.
    2004 A3 Sportback 2.0TDI SE, RNS-E Sat Nav SW0650 TMC, 17" Star Alloys, Xenons, DIS, Rear Mats & Sunblind, Alu trim, Ebony Black pearlescent
    2006 Honda Accord EX i-CTDI, Arctic Blue, Leather, Sat Nav, XCarLink
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Its good just to look at the screen and see it update without a route programmed to see where the holdups/accidents are.
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
