Volks AutosChris Nott
    zia
    Mar 2007
    no base in my a4 cab
    i drive a 04 plate a4 cab,the front 2 door+back 2 door base speakers are not working,its a symphony 11 head unit,i would like to no if they are wired to the head unit or a seperate amp+were is the amp in the car if they are wired to it.thanks for your help.zia
    Jun 2003
    World of my own
    9,813
    If it's non Bose then the fronts run off the HU and the rears off a seperate amp. If it's Bose then they all run off a seperate amp.
    So all you're getting is the tweeters?
    Has this just happened, or has it always been like this?
    Very strange that all 4 woofers would suddenly stop working. If the tweeters are working then it can't be wiring related as they run off the same wiring as the woofers.
