Volks AutosSky Insurance
Results 1 to 14 of 14
    Sep 2003
    Manchester
    340
    Audi A2 with Bose - No FM reception, help?
    The Bose sterio (Audi Symphony) is my Audi A2 has suddenly decided to stop working. The CD works fine, but the FM radio reception is none existant. I just get static and sometimes a very very faint signal (no where near listenable).
    Is there an FM booster AMP anywhere in the car that could be broken?
    Does anyone have any tips on what to check?
    I can't get the head unit out of the dash either, any tips? (edit - I've just bought these off ebay:-
    http://cgi.ebay.co.uk/Audi-Stereo-Re...QQcmdZViewItem)
    ANy comments / suggestions welcome.
    | 2003 Brilliant Black APR'd S3 - SOLD |
    | 2004 Nissan 350Z GT - SOLD|
    | 2004 VXR220 number 7 of 65 - SOLD|
    | 2003 BMW M3 SMG |
    Sep 2003
    Manchester
    340
    anyone?
    | 2003 BMW M3 SMG |
    Sep 2003
    Manchester
    340
    My headunit removal keys turned up today, so just been out and taken the headunit out. All cables secure in the back.
    AM reception still seems to work, no FM at all.
    I pulled fuse 2 (radio) out....to see if it was ok, when I put it back in, when I turn the Headunit on now, it says "SAFE" on the display, and nothing seems to work. I've given up for today. :-(
    (edit to say) Just read the manual, and re-entered the radio code, so it's working again. Tuned into AM 1215 for the time being. CD player working.
    I think it is the Ariel amplifier! Wonder where it is???
    | 2003 BMW M3 SMG |
    mac1403's Avatar
    Sep 2005
    wales uk
    956
    Sounds like the amlifier is not working. Maybe a thought would be to pop down to halfords and buy an Aerial amplifier adapter. This just plugs into the back fo the HU and then your std aerial plugs into that. They are about £10, but it could solve your problem.
    I had the same thing when I changed my OEM HU to aftermarket and that's the route I had to go down. The amplifier has to be connected to a switched live though. All I did to mine was scotch lock it into the wire for the power aeial on the back of the HU. Its all very easy to do......must be cause i managed and I am a dunce when it comes to pointy headed electrical nonsense LOL
    If it doesn't work a tenner is not the end of the world
    Facelift S3, Sprint Blue, Bucket seats, Sunroof, Sat Nav, Bose, Elect Mirrors, Light and Rain, Interior Light pack, Flat Tyre Warning, GSM Phone Prep, Led upgrade, Illuminated speaker grills.
    Sep 2003
    Manchester
    340
    Cheers Mac, I've just ordered one from caraudiodirect. Hould be here by the end of the week and I will give it a try, I'll report back when I get it fitted :-)
    | 2003 BMW M3 SMG |
    Jun 2003
    World of my own
    9,813
    In the meantime you can just disconnect the aerial and poke a wire coathanger or even a small screwdriver into the centre pin on the aerial connection on the back of the HU as a makeshift aerial to test that FM is actually working on the HU.
    When you fit the aerial amp, as already stted you need to connect the flying lead on it to a switched 12v, there are a couple on the back of the HU, do not connect it to the main 12v supply to the HU as this will remain on all the time and will drain the battery.
    Sep 2003
    Manchester
    340
    Quote Originally Posted by AndyMac
    How do I identify the switched 12v supplies? The part turned up so will be trying to fit it some point this week.
    | 2003 BMW M3 SMG |
    Jun 2003
    World of my own
    9,813
    They're the ones shown as a little switch on the diagram on top of the HU.
    Sep 2003
    Manchester
    340
    Cheers Andy, very helpfull :-)
    | 2003 BMW M3 SMG |
    Sep 2003
    Manchester
    340
    Well, I have just fitted the mini AMP and it still doesn't work....
    However if I stick a phillips screw driver in the back, I get FM reception, loud and clear.
    Therefore I am assuming there is a breakage / loose ariel connection somewhere from the back of the HU to where ever the ariel is???
    Is the back windscreen the ariel? I've started taking the boot appart to find it but have not found anything yet. Had to stop because of the rain.
    Help?
    | 2003 BMW M3 SMG |
    BennyB0Y's Avatar
    The Black Phantom
    May 2007
    75
    I've got a similar problem to you as I'm trying to upgrade my head unit, (see this forum) from Symphony II to Symphony II+. Aerial behaviour is poor for AM and FM, but like you, stick a paperclip, screwdriver etc. in the socket connected to the headunit, I get a good reception. I'm sure there's a way to get this working, and am annoyed at Audi for making something like a car aerial so troublesome. I'm still looking for a solution. I'm finding it hard to refuse that this one problem will not allow me to use this newer headunit.
    Audi A4 2.0 TDI (140 PS) SE Avant, Parking Sensors, 17" OEM Alloys, Cruise Control, GSM Mobile Prep in Armrest
    Feb 2007
    22
    Hi pure
    A guy from the A2oc had similar problems with radio reception - see links for more info on aerial amp locations etc
    http://www.a2oc.net/forum/showthread...ghlight=aerial
    Not sure if you need to join the club (its free) to read the links
    Cheers Spike
    BennyB0Y's Avatar
    The Black Phantom
    May 2007
    75
    Wonder if this any help in an Audiworld forum
    Sep 2003
    Manchester
    340
    I think I have found what the problem "could" be. I had a look at those posts on a2oc and found the diversity antenna in the boot near the battery. It was full of water (submerged) so I guess it has blown.
    Replacement part is £90 from audi tho or £80 from vag-parts. I think I am going to buy a new part and see if that helps.
    I took all the trim off the boot etc and all connections were in place and seemed ok.
    | 2003 BMW M3 SMG |
