Sky InsuranceVolks Autos
Thread: Y Splitters
    Mar 2007
    74
    Y Splitters
    I have never used these rca splitters before and i had assumed you get a connection to the current rca's which feeds out into 2 sets of rca's. However looking around i have found you can only get one femal to 2 males. Does this not only send the left or right signal to the new sets of rca's? And then when i change the balance from left to right how will it work with these?
    I have also managed to locate this box at maplin:
    http://www.maplin.co.uk/Module.aspx?...t15&doy=search
    Will this be a better option to go for or does it not make any real difference?
    Dec 2006
    barnsley
    1,013
    this is more like what you want
    http://cgi.ebay.co.uk/Car-Audio-Subw...QQcmdZViewItem
    connect one of the female ends to the end of your rca cable and this then splits into two
    how you connect these to your amps will determine if you sacrifice balance or fading
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Jun 2003
    World of my own
    9,813
    you plug the right RCA into the female socket and feed each male to the right input of both amps, then do the same for the left. So you need 2 sets and probably a short RCA extension if feeding 2 seperate amps (depending on how far apart the amps will be).
    Mar 2007
    74
    That sounds fine. However i have one 2 channel amp running the fronts and one 4 channel amp running the sub and the rears. So i don't think i am able to feed the right into both right channels as the 4 channel amp has left and right so one set will have to go to feed into the left channel. (I want to control it so that the rear control is for sub and rear speakers).
    The only other option i can think of is to run the rears of the 2 channel amp and the fronts and sub off the 4 channel amp? (Not my preferred option). However once again his may cause the same problem as there is not really a left or right channel on a 2 channel amp?
    Mar 2007
    74
    Unless you mean...
    Sorry i might be getting confused here. Do you mean that the splitter should be fed out so that the red termial should feed out into a set of rca's which each go into the red rca terminals of the amp and the same for the black terminal?
    Jun 2003
    World of my own
    9,813
    Yes, blimey it's not exactly complicated
