Monster MotorsportEM Tuning
    mjhamilton's Avatar
    Broooom Brooom Brooom!!
    Jul 2003
    United Kingdom
    26
    Lightbulb A6 1998 Electric Aerial Removal
    Dumb question...
    want to service my leccy aerial (can't get it all the way up anymore.. ooohh eerrr).... how does it come off the car... the rubber on the outside is knackered so I don't want to pull at this unless I have to
    I suspect I have to cut/remove this to expose the top nut.. then undo this to then drop the module out from inside after removing the aerial line and power connector..
    ... can someone confirm
    1997/8 A6SE 2.4 30V Dark Green Metalic, had for 5 years now... old lady has only 30k miles..
    simonwjones's Avatar
    Aug 2005
    staffs uk
    344
    I would suspect its wheel off and remove the plastic trim within the arch.
    The aerial should unbolt from underneath here, remove the wires and then pull out from the top.
    That is unless someone with elswin can tell you otherwise
    Simon
    A6 2.5tdi Quattro Sport 180
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    RNS-E, Audi BT, Phatnoise
    mjhamilton's Avatar
    Jul 2003
    United Kingdom
    26
    the aerial can be seen inside the cupboard that houses the cd changer and sat nav modules..... doesn't appear to be attached to the chassis in anyway and no way to release from the inside
    Aug 2005
    staffs uk
    344
    Is there not a circlip holding it in????
    Simon
