EM TuningSky Insurance
Results 1 to 29 of 29
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    can anyone recomend a decent sub for Ł100 ?
    i got about Ł100 to spend on a sub ive been told about 12" pioneer subs apprently they are the don
    200 Horses nice !!!
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    ive found this legacy sub on ebay any thoughts on these ?
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...0219&rd=1&rd=1
    200 Horses nice !!!
    Jun 2003
    World of my own
    9,813
    Do you want a dual voice coil sub?
    TBH it's the quality of the amp & the enclosure that's more important.
    If your amp is stable at 2ohms then you could wire the VC's in parallel on that model to give you a 2 ohm load.
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    what does a dual voice coil do mean and what does it do ?
    my current amp is a jbl gto 75.2 but i was going to get a better one in the future so it could run a 1000w + sub
    200 Horses nice !!!
    Jun 2003
    World of my own
    9,813
    Every speaker has a voice coil, it's the bit that transfers the power from the amp to the cone of the speaker. And the bit that breaks if you push too much power through it i.e. a blown speaker means the voice coil has fractured or broken.
    The VC also dictates impedance of the speaker i.e. the electrical resistance it presents to the circuit. Dual VC subs were developed to allow more flexibility in how the sub can be wired up i.e. each VC can be powered by a seperate amp, or a seperate channel on the same amp, or wired in series to present a higher impedance or wired in parallel to present a lower impedance.
    Really you'd only ever want to drive it as either a 4 ohm or 2 ohm load on the amp. A 2ohm load means you can get close to twice the umph from it using the same amount of power, but the amp has to be designed to be used with a 2 ohm load otherwise it'll shutdown or burn out.
    TBH most amps are not stable at 2ohm when bridged, but can drive 2 ohm loads unbridged. So with your amp it's rated at 2 x 97wrms @14.4v into 4 ohms but the power jumps up to 2 x 145wrms into 2 ohms. But as it's not stable at 2 ohms bridged then there's little point buying a DVC sub.
    If you want huge power then you won't do much better than the Alpine SWX-1042D's that CAD have on special offer - £150 with 1000wrms capability. Alpine are hugely under spec'd as well so it'll take even more power than that.
    http://www.caraudiodirect.co.uk/alpi...b63b4dd396f4de
    Steer clear of any sub or amp that only lists peak power. Peak power means nothing, RMS is the only meaningful indication of power.
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    £150 is out my range at the mo i thought alpine where a good brand as they make great headunits but im told they dont make good subs
    200 Horses nice !!!
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    200 Horses nice !!!
    Jun 2003
    World of my own
    9,813
    Yes Alpine are shyte but some no brand item on ebay is perfect! WTF?
    As I said steer clear of anything quoting peak power - it's for the Saxo boys innit?
    Alpine are not the best on the market granted, but you won't do better on that budget. If you want to pay Ł500-Ł900 for a sub then there are better brands out there.
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    so can i get a 12" 1000w rms dual voice coil sub for £100 or even better a 15" ?
    200 Horses nice !!!
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    this is the sub thats been recomended to me
    200 Horses nice !!!
    Jun 2003
    World of my own
    9,813
    Sounds like you're really going for looks/dB's rather than anything approaching quality so I'll bow out here
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    200 Horses nice !!!
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    sorry forgot the link
    200 Horses nice !!!
    Dec 2006
    barnsley
    919
    what amp will be driving this please ???
    you dont have a to have a sub with silly silly numbers printed on the side for it to sound good bigger is not allways better
    heres a few things on ebay at the moment which when powered correctly
    and in the correct box will sound very very good
    http://cgi.ebay.co.uk/12-Precision-P...QQcmdZViewItem
    this is an old school classic subwoofer which is sought after nowadays if you can get ti for anywhere near that price its an absoloubt bargain
    http://cgi.ebay.co.uk/DLS-W312B-12-S...QQcmdZViewItem
    halve decent sub for not a lot of money
    http://cgi.ebay.co.uk/JL-SUBWOOFER-1...QQcmdZViewItem
    jl audio should work well if powered correctly one of the older models but still good
    http://cgi.ebay.co.uk/12-Focal-compe...QQcmdZViewItem
    this is an all in one (built in amp) but if you can get it for the right money then its a bargain will have to be collected but anything under Ł100 for this is a steal even with a trip out in the car to fetch it
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    now im a bit confused all them subs have low watts rms ie. 250w i allready have two 15" 250w subs and get told there crap wattage
    200 Horses nice !!!
    a4singh's Avatar
    Oct 2006
    Maidenhead
    115
    big bloke, the pioneer subs you are looking at (SPL3004 1000w RMS) i have 2 of those in my a4 (used to have four but got too heavy)... they sound crazy! the bass is really clear, and if you look around you should be able to get them for around 85 pounds. you'l need a decent amp to power them though...
    with these pioneers, u can pump them loud, and they'll take it, im running two of them at 1 ohm and have a wcc amp powering them which is 2350 watts rms at 1 ohm so they do go very very loud. unless you wana spend 400-500 for alpines or kickers, these are the best out at the moment in my opinion...
    Gone: 1998 Audi A4 1.8T Sport
    Coming: Who knows?
    a4singh's Avatar
    Oct 2006
    Maidenhead
    115
    85 delivered that is....
    Coming: Who knows?
    Dec 2006
    barnsley
    919
    there is a big differance between quantity and quality
    if you want your system loud then buy the pioneers at Ł85 but youll also need a good amp to power them properly and a box which is big enough to house the woofer or woofers however they are nowhere near the quality of the others i have mentioned earlier
    so if you want quality which can go quite loud when you thrash it stick to the ones ive mentioned
    r.m.s rating on a sub means very little as theres lots of other variables like sensitivity which makea huge differance
    r.m.s rating on an amp means everything do not take any notice of peak power,max power,max output readings or any other bull****
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    Quote Originally Posted by a4singh
    ive read reviews on the sub and they have all been good i think im going to get it and then look for a mono amp to run it
    200 Horses nice !!!
    AJO
    Sep 2006
    135
    As people have said its nothing to do with the wattage of the sub!
    is better to have a lower power sub than the power of the amp that way you get more controll over the sub!
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    so what then keep my two 250w 15" kicker comps ?
    200 Horses nice !!!
    Dec 2006
    barnsley
    919
    it depends on you
    you need to make up your mind what you want from the system
    you allready have some gear so why are you changing it ??? (bigger numbers dont mean it sounds better)
    do you want it so loud you cant hear yourself think (in which case keep the fifteens put them in a ported box tuned at the correct frequency and buy a good amp to drive them correctly)
    do you want clear accurate reproduction and something that resembles music as opposed to road noise (in which case buy a single 10 or 12 in a sealed box with a capable amp )
    the only rms ratings you should take notice of are those on an amplifier
    the ones on a sub mean ****
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    well i was happy with my current setup it will make your head hurt and you can feel the air in the car move but when i mentioned they are only 250w all i got was there ****
    200 Horses nice !!!
    Bash_A3's Avatar
    Mar 2007
    Surrey
    233
    Quote Originally Posted by bigblokey0
    if you want to impress your friends then buy what they recommend!
    personally i'd go for a quailty 8/10/12" sub in a sealed box.
    Bare in mind you'll be massively under powering that 1000wrms sub with your amp, could even damage it.
    Audi A3 2001 1.8T Black - Hyperboost DV, BMC Filter, Kicker 8" Sub in custom Stealth box.
    Manager of the AS fantasy football league "Super Hoops" ... come on you R's!!!
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    Quote Originally Posted by Bash_A3
    i know that but i can buy a bigger amp if i get a bigger sub its really difficult to know what to do ive got the world and his wife all telling me different things what i want out of my system is clear sound but with bass that will make your ears bleed if it wanted to
    200 Horses nice !!!
    Dec 2006
    barnsley
    919
    im sorry but what you want takes a lot of money and a lot of space
    go here http://www.talkaudio.co.uk/vbb/forumdisplay.php?f=28
    join up for free and then post what subs you have and what kind of sound you would like the guys in the spl streetbass section should be able to sort you out with the correct sized box as well specifications
    what you will need is a serous amp to be able to drive them correctly
    just because some marketing prick decided to put 250 watts on your sub doesnt mean if you put more than that through them that they will blow up
    the old cerwin vega subs were rated at 500 wrms yet when tested to destruction they managed to take 4.5 kw before the coils went
    9 times there reccomendation
    you are more likely to kill a sub with too little power which causes the amplifier outputs to clip
  28. #27
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    thats another reason i chose my kickers allthough rated at 250w rms they came 1st in a mag when they tested them to destruction they went well above there peak rating
    200 Horses nice !!!
  29. #28
    a4singh's Avatar
    Oct 2006
    Maidenhead
    115
    if you are still thinking about going for these, make sure you get an amp that is 1 ohm stable. i had one advertised in the classifieds if you're interested its the same as what im running atm but never used!
    Coming: Who knows?
  30. #29
    bigblokey0's Avatar
    Jul 2006
    shropshire
    742
    well having talked to the guys on talk audio they have advised me to keep my subs as they are not half bad and just buy a more powerfull amp so ill stick with what i got and just get an amp that runs 500wrms @2 ohm
    200 Horses nice !!!
