tv tuner and navi wiring!!
Mcgough
Newcastle
Just got a Tv tuner, Aerials and the navi unit :jump:
.......But im struggling with getting the wiring diagrams or getting plugs apart to see what pins each wire is on- can some one help???
Tv tuner Wiring harness (32 pins(Nav) 54 pins(tuner))
On the 32 pin plug side i have loose cables, where do these go, cables are as follows...
1)Red
2)Red - grey Stripe
3)Brown
4)Grey -White stripe
5)Grey- Red Stripe
Also another few questions.
1) Best location for the tuner (in a avant ?)
2) Best location for the aerials x 4 (in a avant ?)
3) Both aerials have red and black cables, do i have to source a ground and ign live for both these- if so where from in the car is best to steal them??
All the rest is straight forward, cheers for help in advance kris! +++
Not sure this is going to help at all or just confuse things more..?? But this is the location Audi stick the OEM stuff including aerials.
The wiring diagrams in Elsawin aren't always great and they are a pig to copy and post though so I've not tried with that. Though not all coloured wires you mention are on the diagram.
Overview of fitting locations (Avant)
[URL="http://i164.photobucket.com/albums/u27/Sinny71/A91-10161.jpg"][/URL]
1 - CD changer -R41-
q In glove box
q Connectors → Chapter
q Removing and installing → Chapter
q Checking wiring connection → Chapter
2 - Internal loudspeaker -R70-
q In dash panel (front centre)
3 - Internal microphone -R74-
q Only with BOSE
q In front interior light -W1-
q Function test → Chapter
- Telephone microphone -R38-
4 - Amplifier -R12-
q Behind luggage compartment side trim (right-side)
q Connectors (BOSE) → Chapter
q Removing and installing (BOSE) → Chapter
5 - Window aerials (rear right)
q FM3/TV3/TV4
6 - Right aerial module -R109-
7 - Bass loudspeaker -R100-
8 - Roof aerial with telephone aerial -R65-/navigation aerial -R50-
9 - Rear window aerials
q FM2/TV2
10 - Navigation/TV tuner -J415-
q Behind luggage compartment side trim (left-side)
11 - Aerial module (left-side) -R108-
12 - Window aerials (rear left)
q AM/FM1/TV113 - Bass loudspeaker, rear left -R15-/bass loudspeaker, rear right -R17-
q In rear doors (bottom)
14 - Mid-range/treble loudspeaker, rear left -R34- / mid-range/treble loudspeaker, rear right -R35-
q In rear doors (top)
15 - Bass loudspeaker, front left -R21-/bass loudspeaker, front right -R23-
q At bottom of front doors
16 - Mid-range/treble loudspeaker, front left -R26-/mid-range/treble loudspeaker, front right -R27-
q In front doors (top)
17 - Control unit for navigation system with CD drive -J401-
q In upper section of centre console
Thanks that helps for location!!
Cheers for all the replys on here and naviplus, so in answer to my own question, just incase people need help in future..... i think........
K-line = 1)Red
Positive = 2)Red - grey Stripe
ground = 3)Brown
Can L = 4)Grey -White stripe
Can H = 5)Grey- Red Stripe
Left hand Storage door in Boot
2 on left rear windwon and 2 on right rear window
From the Bose unit (Speaker Amp)
And i take i just break into the wiring in my cars wiring harness or the small link harness between the 2, (behind the navi) to get all the feeds Ch Cl k-line and + - etc
just had a look at bose wiring, which cables are pos and neg?? and the aerials are too tall to point to the sky do they just stick accross the windows???
also the tuner has 2 green and 2 brown aerial inputs, i take it one is left and one is right?? which is which??
Hmmm, wasn't aware you can do that but think I'll have to give it a go tomorrow. Only have v409.1 but will let you know if i works as I'm not far away.
Job done, I'm impessed with that like. Let me know if you still need help with Vagcom.
Cheers sinny ive got most of the stuff installed now, just need to get some proper keys so i can remove the syphony II, do the last 5 wires and im sorted i think!!??
Would like it if you could code mine for me, ive just been told with the kk-line and the 409 shareware i wont be able to do it my self as ill only be able to change upto channel 10:- do you know?
2K
553
770
898
776
