AH FabricationsBadger5
Results 1 to 9 of 9
    Bash_A3's Avatar
    Mar 2007
    Surrey
    233
    Bash's Stealth Sub (8L)
    Well I finally got around to making it, took most of a day but i'm happy with the result. A massive thank you to AndyMac for his VERY informative PDF's... saved me alot of time with wiring and he is a legend for supplying all his info to the community.
    My aim was to make a stealth box to fit the 8" Square Kicker Sub, i'm no carpenter but have dabbled with MDF before... i didnt think doing a curved box like Andy's was within my skill range so i've gone for a more angular approach.
    One pitfall is access to the rear lights is now limited (i.e none!) also I need to make a upper panel which will not foul the sub. Its a tight fit & needs some adjusting but comments welcome!
    Audi A3 2001 1.8T Black - Hyperboost DV, BMC Filter, Kicker 8" Sub in custom Stealth box.
    Manager of the AS fantasy football league "Super Hoops" ... come on you R's!!!
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Good job, nice to see someone taking a different approach to it all. How does it sound?
    [/sarcasm]
    Dec 2006
    barnsley
    1,016
    whats the internal volume of the box ???
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Bash_A3's Avatar
    Mar 2007
    Surrey
    233
    Quote Originally Posted by ChriS3
    i've no idea how it sounds yet, by the end of Sunday I was so exhausted I didnt have the energy to screw the amps down & plug them in. I'll probably hold on til the weekend so i can tune it up properly.
    Quote Originally Posted by dualmono21
    the volume is tricky to work out due to the shape but i'm sure its above the minimum recommended sealed enlcosure for this sub which is 0.33 cubic ft. The max rec sealed is 0.75 cubic ft. I'll measure it up soon out of curiosity.
    Bash_A3's Avatar
    Mar 2007
    Surrey
    233
    Worked out the volume, 0.331 Ft3
    not ideal but pretty close! I'll have a feel around it to see if theres anyway of expanding deeper.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Looks good!
    Is there enough room for the throw to clear plastic trim? Looks pretty tight!
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Bash_A3's Avatar
    Mar 2007
    Surrey
    233
    you are right its very tight! the top is clear but the bottom needs to sink in further or I need to wedge the panel away slightly - it only has 2cm clear from the rubber surround. When its running i'll see how long the excursion is then start adjusting
    I'm also thinking about picking up a spare rear trim section from another A3 so I can cut off the lip and make a custom netting over the top section.
    Jun 2003
    World of my own
    9,813
    Can I pass over manufacturing duties to you now Bash?
    That will sound excellent, well done!
    Bash_A3's Avatar
    Mar 2007
    Surrey
    233
    hehe no way Andy, i felt like i'd died of heat exhaustion by the end of the weekend! I think your boxes are far more pratical if only for the access to the rear lights, I can see how it took u lots of prototypes to get the perfect fit around the arch... its a real pain in that corner with the seam & other bits sticking out.
    another pitfall is these subs are pretty in-efficient so i'll probably be mounting the main amp to the boot floor as i'm worried about it overheating. Its a 1000w Kenwood amp with fan + I've another smaller Kenwood amp for the corners.
    I cant wait to hear it now
