Hi
I did my install on Friday evening.. Really straight forward, sorry no pics. Broke my camera on holiday not got replacement yet.
It took me about 30mins to get it all installed.. Just simply remove the old Symphony II unit, Plug in the adapter cable that I got from eBay. Remove the plastic casing from the diversity antenna and install it to the new diversity and Radio antenna adapter. You will also need to connect the aerial cable to this adapter.
I placed the GPS aerial above the glove box as I did not have the correct torx driver to remove the screws for the Speedo. The glove box has 5 blots that you need to remove. Three are in the glove box on the top as you open it, and the other two right underneath in the foot well. Pull the glove box out and you will see a steel cross-member. I attached the GPS to this and cable tied the wires back top the RNS-E.
Once this is done, just plug in the main plug to the RNS-E unit, attached the GPS aerial and the double fakra connecter. Make sure you have it the right way round.
Then make sure you have tucked all the wires to one side before sliding the RNS-E back in. I left the glove box out as you can get access to the back of the RNS-E and all the cables. This helps you to move the adapter blocks and cables out the way if they get caught anywhere while sliding the unit back. Once the unit is slid back you should hear it click, this means it has locked back in place.
Once you have done this, test the unit make sure you are getting a GPS signal AM/FM reception etc. Once you are happy, put the glovebox back in.
Can't belive how much better the sound is compared to the symphony II system, and also looks great. I get around 4-5 Sat signals with the GPS above the glovebox. Have had it go up to 6 & 7 too..
I got all my install info from
http://www.navplus.us/forum/viewtopic.php?t=527
http://www.navplus.us/forum/viewtopic.php?t=462
For anyone interested doing the same thing..
Hope this makes sense, sorry for lack of photos..
Pal
