Volks AutosEM Tuning
Results 1 to 19 of 19
    Feb 2007
    Running power wire for A4 B5 and speakers
    Hi guys, 3 quick questions
    1) I have a A4 B5 with the 2.6 v6 and I'm trying to run a power wire from the battery through to the cabin and cant seem to find any gromet etc to run it through. Have read through the forums and got a fair idea how to do it (coat hanger etc) and I've done it easily on previous cars I have owned but there is very limited space around the engine to even see part of the firewall to run a wire through. If anyone could tell me where to run the wire through or has any diagrams it would be much appreciated.
    2) Also my car has the rear nokia speakers, are these run off a factory amp and if so where is this located?
    3) Thirdly, how do I get the front plastic speaker grills off without breaking them, they dont seem to want to pop off?
    SamDude's Avatar
    Jan 2007
    London
    2,091
    3) You have to remove the door card to get the grilles off. I found out the hard way and snapped the passenger side grille off...
    Jun 2003
    World of my own
    9,813
    You can run power through the back of the ECU cover, this drops down into the drivers footwell, just remove the visible screws on the top of the ECU cover (under the drivers wiper) and this should give you enough room to prise up the top and see into the footwell. Shine a torch up from the footwell and it'll show you where the power needs to run.
    The rears are run off an amp bolted to the left rear speaker. If you are replacing the rears then the whole rear parcel shelf cover needs to be removed to get to them. Don't try prising off the grills as they are secured to the cover from underneath.
    Feb 2007
    Thanks for the replies guys, brilliant!
    SamDude's Avatar
    Jan 2007
    London
    2,091
    Quote Originally Posted by Fluid36
    There's a button for that you know....
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    have a look here Andy "THE MAN" Mac helpful as always
    Wiring Amplifier to Symphony HU ?
    scroll down to see what the amp looks like and also a pic of where to route this
    i might have a go on tuesday of running the power cable
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Feb 2007
    Quote Originally Posted by SamDude
    huh?
    Feb 2007
    cheers rasA4
    Feb 2007
    Oh you mean the search button I assume,
    I did search but couldn't find what I wanted, thanks for the feedback none the less dude.
    Jun 2003
    World of my own
    9,813
    I think he meant the "thanks" button
    SamDude's Avatar
    Jan 2007
    London
    2,091
    Quote Originally Posted by AndyMac
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Fishing for thanks are we Sam??
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I ran my power cable through the passenger side, what i did was removed the glovebox (dead easy) and then you can see several grommets that pass through the bulkhead into the engine bay.
    I ran the wire up and into the space next to the heater intake, which on my car is covered by a plastic shield, under which is the pollen filter.
    To run it to the back of the car (where my amp is) I removed all the side trim (and broke some in the process) and then removed the side bolster of the rear seat, which removes from the bottom and swings up. this will allow you to enter the boot. There should be a big piece of foam there, use this to stop your cable moving about or chafing.
    Chris
    See my images @
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Quote Originally Posted by A4Quattro
    Glad it wasnt only me that broke some trim wasnt that easy to put it all back esp. the B pillar trim nightmare!
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Quote Originally Posted by rasA4
    That made me snigger! It was a disaster!
    Chris
    See my images @
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    i remember it well my fingers where aching for days man!
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I think I shed blood.
    A job's not a job unless you bleed.
    Chris
    See my images @
    SamDude's Avatar
    Jan 2007
    London
    2,091
    Basically,
    Post whoring/thanks whoring - it's all the same, innit?
    ....at the end of the day
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    you fooker!
    Chris
    See my images @
