EM TuningVolks Autos
Results 1 to 10 of 10
    Mar 2007
    Newbury, UK
    82
    Bluetooth Problems
    I keep finding when driving along my DIS says 'BT off' then soon after 'BT on'. It happens randomly, perhaps three times in a journey or perhaps none.
    I keep my phone in the drink older just behind the handbrake. Would this be a problem with the phone or the bluetooth module in the car?
    Can anyone help?
    Phantom Black Sportback 2.0 TDi 140 S-line.
    Options: Full Leather, Symphony, Bose and Bluetooth
    OEM-Mods:Ambient & Map Light
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    Read through this thread, about half way down I talk about problems I first had.
    Anyone own a sony ericsson K800i?
    hopefully should help you
    cheers
    Simon
    A6 3.0TDI Quattro Avant Le Mans
    A6 2.5tdi Quattro Sport 180 Sadly Missed
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    SatNav, BT, AMI, DAB
    Mar 2007
    Newbury, UK
    82
    Ok, after that read I'm understanding that contacts with multiple numbers need to be categorised using either Home, Mobile or General. Surely this is onlt relevant to Bluetooth with RNS-E not Bluetooth with Symphony (which I have).
    Other than that all can think in the firmware on my phone, a Nokia E50.
    Thanks anyway
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    That's your problem, an E50. Symbian Series phones by nokia are know for problems with BT kits in Audis. I would not recommend any E or N series nokia for use in an Audi unless you have the newA6/A8 or Q7 with SAP profile phone kit.
    Mar 2007
    Newbury, UK
    82
    Oh Great :-(,
    Thanks for the information, I'll know for next time
    Mar 2007
    Newbury, UK
    82
    Ok, I have ditched the E50 as it was probably the worst phone to live with. I now have a Nokia 6300, which is so much better. However Bluetooth in the car is still giving me problems, even though I specifically choose a phone without Symbian. Do you think that my Audi Bluetooth module is at fault?
    Any help guys?
    C_Audiboy's Avatar
    Vroom Vroom
    Nov 2004
    Glasgow
    811
    Have you tried it with a 'known good' handset with the Audi Bluetooth?
    I had the same issue with my Sony Ericsson K800i. I found that it was to do with the last numbers I had last dialed. Clearing these records provided a stable connection, when it would drop out again I knew it was caused by the last number dialed (hope this makes sense?).
    Its not just limited to your Symphony + Bluetooth setup. I had the same problem with both Symphony + Bluetooth and RNS-E + Bluetooth.
    987 Boxster 2.7 (05) - Current
    A3 2.0T Quattro S-Line (55) - gone
    S3 Quattro (02) - gone
    Mar 2007
    Newbury, UK
    82
    Thanks for the help mate but I don't know anyone with the K800i. I'll try removing recent call list too.
    Thanks again
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    my K800 works fine although my Ipaq does the disconnect thing. Its worse when on battery (not charging)
    Porsche 997 Carrera 4 S - Black, Sport Chrono, Sport seats, PCM, Nav, Tel, Park assist and rear wiper (Yes!, its an option!)
    2012 Audi Q7 Sline Plus - Daytona Grey ,Nav+, Wheel upgrade, Storage and tow pack.
    Gone -2007 S5 4.2 ,2008 S3, 2007 TTC 3.2, 2007 RS4 Saloon, 2004 S4 Saloon, 2006 A4 2.0T Sline SE,2002 A3 3.2 Sline, 2001 A4 1.8T,2001 Boxster, 1983 911SC,1992 Corrado G60,1988 GTi.
    (Vag com owner)
    Mar 2006
    UK
    I also have the same problem with my K800i dropping off randomly.
    Whenevr this happens I delete my recent calls list and it's then stable again for weeks.
