Chris NottAH Fabrications
    Naresh's Avatar
    Essex
    260
    Security decoding Sony Stereo
    Hi does anyone know how to unlock a Sony cassette stereo (old style XR C450RDS model or similar) because the one in my sister's car has locked recently since the battery was changed! Basically it is stuck in Date mode and nothing else will work!
    She doesn't have the manual and I can't find it on the web so are there any clever people out there who know the normal procedure for unlocking Sony units i.e what buttons to press? There is a sticker on the back of the face but I wasn't sure how to use this!
    Thanks in advance!
    May 2003
    UK
    45
    Re: Security decoding Sony Stereo
    The XR-C450RDS isn't a coded unit.
    You could try pressing the reset button behind the front panel. Failing that I would disconnect the power from the unit (pull main plug out of the back) then reconnect after about 30 seconds.
    If the unit is still in the same condition I would suggest that it has been "spiked" when the new battery was connected causing an internal fault.
    Andy
