AH FabricationsVolks Autos
Results 1 to 10 of 10
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    rear door speakers
    hi i have a face lift A4 saloon with symphony HU just wanted know if the rear doors are pre-wired for speakers?
    thanks
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,347
    Hi, Ras. Long time, no speak. B5 A4 saloon has no wiring to rear doors for speakers. I wanted to install rear door speakers on my old 2.8Q but no joy.
    Take care, old buddy.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Unhappy
    cheers Jeff
    ill have to work out a way to wire them in hopefully i dont have to run them all they way from the HU? i have the speakers already on some new door cards.
    Jun 2003
    World of my own
    9,813
    Audi HU can't drive rear speakers. It only has an internal amp for the fronts. You'll need to either take a feed from the rears in the back shelf or install a small amp to drive them.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Cheers Andy do i just tee in L & R speaker connections?
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Andy also im looking for a sub amp that i can control the loudness from the from like a knob or something so when children in the car i can turn it down.
    Jun 2003
    World of my own
    9,813
    Have a look for one with a wireless remote control, otherwise you're looking at quite a bit of rewiring
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Quote Originally Posted by AndyMac
    any particular makes or models its a mine field out there?
    im also thinking would the rear EXISTING amp be ok if i connect the rear door speakers to this>?
    thanks again
    Jun 2003
    World of my own
    9,813
    No definately not. It's only 2 x 20w and the size of a matchbox, you'd need to hook up the door speakers in series with the rear deck speakers otherwise you'll be halving the impedance which will kill the stock amp.
    If you're installing a sub I'd disconnect the rear deck speakers and just rewire the amp to the rear doors. The deck speakers sound awful and will sound even worse with a sub thumping up behind them.
    I'm sure I saw some amps that had wireless remotes, but can't see any on the net now. There are a few with wired bass controllers, this Kenwood is a bargain at £120 for 500wrms bridged.
    http://caraudiosecurity.com/shop/pro...s_id/3569.html
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    wow that amps a beast 280mm x 286mm can i mount this to the parcel shelf underside with the help of mdf?
