JMB RetrofitsChris Nott
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Satnav charger cable - Fused?
    I have a Road Angel and a satnav, both of which came with charger cables that plug into the cigarette lighter. I had both of them hard wired in, but they were done by different installers.
    The guy who did the RA cut the cigar lighter plug off & connected the bare live and earth wires with an in-line fuse. The guy who did the satnav left the plug in place, connected new wiring to the end of it and taped it all up.
    The satnav has just stopped charging, and I can't figure out why. I can't find an in-line fuse anywhere in its circuit. So my question is: Does the cigarette lighter plug have its own fuse built in?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Ok, have had the car inspected by someone who knows what he's doing:
    Firstly, the plug on the satnav cable was left in place for a reason. It's not just a connector, it contains a mini circuit board with a voltage regulator.
    Secondly, the reason it's not charging is that the mini circuit board is fcuked and can't be repaired. New cable ordered from Ebay for £6.
    Thirdly, the satnav cabled is fused, through the same fuse as the Road Angel cable. It also uses the same earth, which is handy to know for the future.
    Randles's Avatar
    Feb 2007
    South Wales
    96
    Thanks for thr info mate may come in handy for the future.
    Glad you got to the bottom of it
