Chris NottAH Fabrications
Results 1 to 8 of 8
    Sep 2006
    Chester
    71
    Nokia phone cradle – S3
    Does anyone know of a good phone cradle mount for a 2003 S3 with a Symphony II? I was looking at the mounts on Dashmount (http://www.dashmount.co.uk/audi.htm) but it says “not S3 with Symphony”. I’m after something reasonably neat looking that won’t damage the dash and will take a standard Nokia 6233 cradle.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,678
    What you wanna use is the nokia universal cradle & the damage free bracket which slids in down the side of your stereo or air con unit (then bolted in). I have a Nokia car bluetooth kit which works the same. search car communications they sell all the bits your ll need.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Sep 2006
    Chester
    71
    Cheers, I had a look and they seem to sell Dashmount brackets so I guess if you have one in your S3 with a Symphony II they must be ok. I already have the Nokia bluetooth kit installed so just need somewhere to mount a cradle.
    Does it get in the way of anything? I've got a Nokia 6233 which unfortunately requires a brick sized cradle.
    MattS3's Avatar
    Jul 2005
    North Norfolk
    503
    I have one of these for sale somewhere I think (The dashmount bracket) I had it fitted in my S3 until I got a bluetooth kit
    I'll post it to you for Ł12 if you want it. (and I can find it!)
    2011 S3 Sportback S-tronic Black Edition - Revo stage 1 - Milltek Non Res Catback
    2003 S4 V8 Saloon Manual Milltek Cat Back - Sold
    Sep 2006
    Chester
    71
    Thanks Matt but I've already ordered one from Dashmount. I emailed them and they told me the note on their site about it not fitting the S3 is due to the extra sound proofing and I might need to shave some of the platic inner trim for a snug fit.
    Nov 2005
    UK
    1,678
    You have two option at what height you can mount it:
    1. the bolt thats holds the DIN.
    2. the bolt that holds the air unit in.
    Option 2 is best as your cup holder wont extend fully, your ll also have to play around with your bracket so the glove box doesnt hit it when opening. Otherwise the only restriction i have some tape buttons (no big deal) & the passenger heated seat which also doesnt bother me.
    You do realise you can connect a cable to your cradle so it charges the phone.
    Matt
    wanted for 8L S3:
    Milltek system
    Sep 2006
    Chester
    71
    That’s very useful info cheers. Getting in the way of the heated seat switch puts me off a bit and I’ve got a nasty feeling the 6233 cradle will get in the way more than the other cradles.
    I had a cradle in my last car but thought I'd see how it went with just bluetooth so I didn't have to mess up the look of the dash in my S3, I miss the charging and phone being easy to see when driving though. I’ll just have to try it I guess.
    Nov 2005
    UK
    1,678
    well i had a 6230 cradle previously which wasnt a problem then i got an N73. After attemping to source a N73 cradle i found out nokia dont make them so i though improvisation is needed. It just so happened that a phone exsisted which was the exact same dimesnsions as the N73 & has its own cradle. Ordered one & it worked. The cradle is pretty big but to be honest i would rather i can charge my phone, get the better connection through the data lead (opposed to BT) & of course my phone stays in the cradle from A - B.
    You shouldnt have any problems as long a you follow my previous post.
    wanted for 8L S3:
    Milltek system
