AH FabricationsChris Nott
    Mar 2005
    Swindon, UK
    48
    Wiring Amp into S3
    Just started to upgrade the sound system in my S3. Ive changed the wiring using AndyMac's pinout drawing whichs gives me a rear left and right preout. Trouble is the amp i've got needs an input for each chanel. I can have the rear speakers working but not the sub and vice versa depending on which channel the RCA goes into.
    Can I split the preout signal coming from the headunit?
    Any other ideas?
    James
    Jun 2003
    World of my own
    9,813
    Yes James you can just get two "Y" splitters and feed the rear pre-outs to all 4 channels. Might be worth checking that the amp does not have a switch to do this, most decent amps have an input select switch which can take a single input and feed it internally to all 4 channels, or some have a ch1/2 RCA output, which you can then connect to ch3/4 with a short RCA lead.
    Mar 2005
    Swindon, UK
    48
    Thanks for the quick reply, My Amp is about 5 years old and has none of what you mentioned. What i've done is brought a pre-out lead adapter and run the remote, front and rear preouts to the rear of the car. The front output is running the sub via a bridged output and the rear out is running the speakers via the two remaining channels. Ive not powered it up yet due to running out of light. Before I do is there anything wrong with what ive done?
    Jun 2003
    World of my own
    9,813
    Yes that's a better solution as it'll enable you to use the fader to give you sub level control.
