AH FabricationsVolks Autos
Thread: ISO adapter
    Faulty's Avatar
    Dec 2006
    Scottish Borders
    46
    ISO adapter
    Hi, can any tell me what ISO adapter i need to fit a Kenwood headunit in a 1997 A4?
    Hopefully not the Ł30 adapter that ive seen!
    http://www.caraudiodirect.co.uk/audi...ut-p-1349.html
    Faulty's Avatar
    Dec 2006
    Scottish Borders
    46
    Oh and just out of interest, has anyone tried this headunit and knows what its like?
    http://www.caraudiodirect.co.uk/kenw...ck-p-5473.html
    Cheers.
    Jun 2003
    World of my own
    9,813
    If you just rewire the rear speakers back to the HU then you won't need any adapters and you'll improve the sound as well. The adapter is only needed to provide a pre-out signal to the crappy little rear amp in the A4 (bolted to the left rear speaker magnet) on the non Bose system. Just run some speaker cable straight to the rear speakers and bypass the amp.
    If you have the Bose system then you'll need the one listed for Bose.
    Faulty's Avatar
    Dec 2006
    Scottish Borders
    46
    How do i tell if ive got a Bose system or not?
    Im also considering a Blaupunkt as thats what ive got in just now, i didnt fit it but was told i dont need any adaptors for that make.
    http://www.caraudiodirect.co.uk/blau...66-p-5420.html
    Jun 2003
    World of my own
    9,813
    Have a look at the rear speakers from inside the boot. If the left one has some gubbins attached to it (some metal work & electronics) then you have the non Bose system. If the speakers are Bose they should have something on them relating to Bose, and they will be driven off a seperate amp hidden in the boot.
    Blaupunkt is just a straight plug & play though you may have to swap the perm live & ignition on live as Audi wire them back to front. If you already have an aftermarket HU then this probably has already been done.
    Faulty's Avatar
    Dec 2006
    Scottish Borders
    46
    Thanks Andy, the car is in the garage just now so just have to wait to find out what speakers ive got.
    About the wire swapping, i fitted the aftermarket Blaupunkt myself but never swapped any wires (novice as you may have nocticed!), it works fine until the ignition is off then it stop playing. Im guessing thats due to me not swapping the wires yes?
