AH FabricationsSky Insurance
    Nov 2006
    71
    radio amplifier? microphone location?
    Hello,
    Im awaiting the arival of the Becker grand prix head unit, can someone explain to me if i need a ariel booster/amplifier, am i correct in saying that this is an integral part of the stock hu.........and if i do need one would anyone know of a part number for autuoeads as this is what the local shop stocks.
    Also im not into gizmos, hence the choice of headunit, but even this one comes with some sort of bluetooth device that enables your mobile phone to play through your speakers, and for you to talk back via a microphone........so my question is where should this microphone be fitted, and if you could give me a brief route to take for wireing to where you recommend...
    thanks
    Fenian...
    Jun 2003
    World of my own
    9,813
    Autoleads products are generally shyte, I'd order the Maystar one from here:
    http://www.caraudiodirect.co.uk/aeri...tor-p-211.html
    Or, I think there is only one, it's not specific to Audi.
    I mounted my mic for car kit next to the centre lights in the headlining, unscrew and prise out the light cluster, then you can feed the wire under the edge of the headlining along the top of the windscreen and down the pillar without having to remove the trim.
    Nov 2006
    71
    you are da MAN.....cheers
