AH FabricationsEM Tuning
    Pete69zx
    A3 8L front speaker upgrade option...?
    Andy Mac this is possibly another one for you...
    What is the max mounting depth for the front speakers in an A3 8L?
    I ideally want, the greatest RMS speaker i can find, allthough quality is the deciding factor here (as im sure it is with anyone that enjoys good clear precise music).
    As an example i have found these possibilties...
    Magnat Xcess 102
    Principle - 2 way coax system
    Power Handling RMS/max. - 60 / 110 Watts
    Impedance - 4 Ohms
    Frequency response - 42 - 32000 Hz
    Crossover Frequencies - 3800 Hz
    Sound pressure level - 90 dB
    DIN-Diameter - 100 mm
    Outer diameter - 139 mm with grille
    Cutting out - 94 mm
    Mounting depth - 48 mm
    Infinity Kappa 42.7i
    Diameter: 4" (10cm)
    Power Handling, RMS: 50 watts
    Power Handling, Peak: 150 watts
    Sensitivity (2.83V/1m): 93dB
    Frequency Response: 75Hz – 25kHz
    Nominal Impedance: 2 Ohms
    Mounting Depth: 46mm
    Cut-Out Diameter: 88mm
    Thoughts & suggestions please.
    Cheers.
    Jun 2003
    World of my own
    9,813
    You have about 60mm, but that needs to include the adapter ring neede to be able to mount the speaker on the original mounting posts. I'd allow 10mm for this so 50mm for speaker depth. I certainly wouldn't use coax speakers in the front doors, you need 2 way components with a 1" tweeter.
    Don't expect too much mid bass from the woofer, remember it is mounted on a flimsy door card loosely hooked onto a metal door. Make sure you Dynamat the hell out of it.
    Pete69zx
    What speakers would you suggest then Andy? :-)
    Jun 2003
    World of my own
    9,813
    I wouldn't spend a fortune on any speakers for the A3. Remember they are being driven off a puny 2 x 20w internal HU amp and they are mounted to the doorcard so you could install the best speakers in the world and the improvement will be marginal.
    The issue with the 8L A3 is bass. Until you address that with a sub then you'll never get anything close to a satisfactory sound.
    I've installed Infinitys 50.5's and Rainbows SLX230's in the past, but you really need to add an amp and filter off the low end as the doorcards can't handle anything approaching even mid bass before they start to struggle.
    If this is the only upgrade you are considering then I'd save a bit more money and add a sub first as this will have the most dramatic improvemnt.
